Author Topic: how do you pop out your ball joints?  (Read 18936 times)
Re: how do you pop out your ball joints?
« Reply #30 on: April 17, 2010, 02:46:08 PM »
I should have said craftsman 1/2" drive ratchet method
+1.5
speedjunky01
« Reply #31 on: April 17, 2010, 04:04:14 PM »
BFH on lower join+jack the car up by the rotor so the weight of the car is pushing down as well  :yes:
SDRAWKCAB
  • D series BALLA!
  • Rhino
« Reply #32 on: April 17, 2010, 04:16:12 PM »
Honda painless ball joint removal
THAT IS FUCKING TITS!
Im doing my shit that way from now on.
All of my LCAs  look like they caught the herp from hotrex because of BFH.
SgtB
« Reply #33 on: April 17, 2010, 04:39:36 PM »
If the spring doesn't pop it, just stand on the rotor. Never fails.
« Reply #34 on: April 17, 2010, 07:15:12 PM »
i unbolt the upper control arm from the car, no chance of messing anything up and no need to mess with cotter pins. i do honda axles in 10 min or less all the time
« Reply #35 on: April 17, 2010, 09:45:57 PM »
Will be using the above tool shortly.
Redoing the front end of the 91 Sedan after snapping a knuckle Monday.
Skunk2 UCA in that pic has 3/8" movement up/down and only has about 5k miles on it.
« Reply #36 on: April 17, 2010, 09:59:29 PM »
How the hell did you manage that?
soontobeDA
« Reply #37 on: April 18, 2010, 12:28:30 AM »
the pitman remover never failed me yet
« Reply #38 on: April 18, 2010, 01:16:48 AM »
just pulling into a parking space.
Broke the LF on the CRX as well, but that was caused by a 2007 Accord :(
hotrex
« Reply #39 on: April 18, 2010, 09:13:51 PM »
i pop mt ball joints with an ak47
« Reply #40 on: April 18, 2010, 10:47:44 PM »
that what you do when you have a herpes outbreak?
« Reply #41 on: April 21, 2010, 12:29:12 AM »
That's how I do mine
Crapsman ftw. It's crazy how easy it is, and how perfectly sized a craftsman socket wrench is for that. It goes next to the ball joint's rubber, between the lca and knuckle if anyone missed that.
One guy I know who works at a rather prestigeous Honda outfit has used a BFH for years. He wails on the side of the LCA, albeit he's bigger than spiker. It deforms the hole just enough to unstick the 2 metal parts. Apparently it's never caused an issue, besides missing a handful of times and destroying other parts... :P
