Author Topic: 98 4 door withz6 swap  (Read 9381 times)
papercuts
« on: April 19, 2010, 12:59:35 PM »
I have a 98 4 door civic and I want to put a 95 d16z6 in it. I have the engine harness from the 98 and the engine harness for the z6.  The harness I have for the shell doesn't have vtec. All I gottaa add is the vtec wire rite?
« Last Edit: April 19, 2010, 03:38:14 PM by papercuts »
Re: 98 4 door withz6 swap
« Reply #1 on: April 19, 2010, 01:06:33 PM »
wat
papercuts
« Reply #2 on: April 19, 2010, 03:38:41 PM »
Fixed.
« Reply #3 on: April 19, 2010, 04:20:56 PM »
if the 4 door is a dx/lx you need to convert the iacv from 3 wire to 2 wire
repin the d16z6 dist with obd2 plugs
papercuts
« Reply #4 on: April 19, 2010, 08:59:13 PM »
Thank u chris. I knew buyin that 800 dollar tranny from you would payoff.  any write ups on the pins swapping on the dizzy plugs
« Reply #5 on: April 20, 2010, 05:32:50 PM »
theres plenty of write ups on depinning plugs out there.  the wiring you just need to get two manuals and compare, match up the right wire with the location
