Author Topic: d16a1 troubles  (Read 11083 times)
shogun
d16a1 troubles
« on: April 19, 2010, 02:50:26 PM »
 a friend of mine did a d16a1 swap and his wiring is kinda shot, the car when starting is only squirting once fuel out of the injectors, the car has spark and with strarting fluid it will start, he says it is probably the resistor box is wierd wrong, how does it have to be wired.. :noel:
Re: d16a1 troubles
« Reply #1 on: April 19, 2010, 03:07:47 PM »
Correctly
Re: d16a1 troubles
« Reply #2 on: April 19, 2010, 04:21:52 PM »
do any of you guys own a service manual?
shogun
Re: d16a1 troubles
« Reply #3 on: April 19, 2010, 04:34:50 PM »
he owns the haynes repair manual
1984-1991 civic
Re: d16a1 troubles
« Reply #4 on: April 19, 2010, 04:38:26 PM »
1984-1991 civic
you guys must be rich thats fuckin awesome
Re: d16a1 troubles
« Reply #5 on: April 19, 2010, 04:39:49 PM »
http://www.realhomemadeturbo.com/forum/index.php?topic=13382.0
only the first post in em. Damn that was hard.
shogun
Re: d16a1 troubles
« Reply #6 on: April 19, 2010, 07:07:30 PM »
well the resistor box is wired as per the diagram, but still no squirting of the injectors, so he is going to get another main relay and see if that is fucking with him, to be honest the car looks like a rats nest in the wiring so i believe its somewhere there
Re: d16a1 troubles
« Reply #7 on: April 20, 2010, 09:58:46 PM »
If the fuel pump cycles for two seconds when you turn the ignition key to the ON position, half of the main relay is fine.  If the injectors have battery voltage with the key in the ON position, then the other half of the main relay is fine. Everything else is ground back through the ECU.
Which year D16A1, what car?  That matters a LOT on where I direct you to look next.  Actually, fuck it, pull the pass seat and look at the ECU.  I specifically want to know if it's gotten wet from being in the floorboard.
Re: d16a1 troubles
« Reply #8 on: April 21, 2010, 01:13:14 AM »
1984-1991 civic
Fail. You ever seen the "CRX/Del Sol" version? Fucking-A, good luck getting an idea how to do shit since they only cover half of each chassis.
2/3 of the problems on a re-wired swap is teh wiring. Most people couldnt' wire a proper noose to hang themselves.
Re: d16a1 troubles
« Reply #9 on: April 21, 2010, 01:30:56 AM »
i resent that.  and i can tie a noose, with 13 coils if you wish.
shogun
Re: d16a1 troubles
« Reply #10 on: April 21, 2010, 02:22:31 AM »
i saw the car and the ecu isnt showing any signs of being wet, and the car was a 88 integra
Re: d16a1 troubles
« Reply #11 on: April 21, 2010, 03:57:25 AM »
was? It caught on fire? I say go and buy another 88 integra for 300 bucks.
shogun
Re: d16a1 troubles
« Reply #12 on: April 21, 2010, 07:38:44 PM »
yes it was an integra that got chopped, the engine got transplanted to a hf crx with a si transmission
Re: d16a1 troubles
« Reply #13 on: April 26, 2010, 08:28:41 PM »
thow some knowledgeabilities my way, JD
http://www.realhomemadeturbo.com/forum/index.php?topic=12307.msg153974#new
