Author Topic: Accord clutch cable issues  (Read 10105 times)
accordepicenter
« on: April 27, 2010, 10:19:24 PM »
im finalizing my old 88 accord, and I installed the clutch cable, pushed the clutch pedal in, and it felt soft, so i tightened the cable up, and tried it again, and it still felt soft (i have a dual diaphram 6 puck clutch, very heavy feel) so i tightened the cable up as far as it will go, and same thing, the clutch pedal feels soft, but the pedal still returns.  I think, if i forgot the bolt for the throwout bearing arm in the trans, then the pedal would go to the floor and not return, and you would feel no resistance at all correct?  Maybe im looking at a cable or pedal issue?  The transmission, clutch and flywheel and throwout bearing and cable are all the same as the last setup and it worked fine, but that was like 2 years ago with the different engine...
Re: Accord clutch cable issues
« Reply #1 on: April 27, 2010, 11:55:21 PM »
how old is the cable? Those things stretch really bad with heavy clutches. Also always buy oem cables unless you like breaking pedal assemblies
« Reply #2 on: April 28, 2010, 12:17:41 AM »
1/2" pipe with a notch cut for supurb adjustment.  my Maltesky Domestic Market 4 puck and Mars pressure plate actually took more tightning than I had on the cable
« Reply #3 on: April 28, 2010, 12:20:04 AM »
that works as well
« Reply #4 on: April 28, 2010, 12:22:00 AM »
Pics?
« Reply #5 on: April 28, 2010, 01:05:08 AM »
Pics?
well its just a piece of galvanized pipe with a notch cut for the cable to fit.  let me see if i can find it.  its in my stash thats all packed up already.
« Reply #6 on: April 28, 2010, 01:08:36 AM »
Pics?
I posted a pic of that mod for you already months ago.
accordepicenter
« Reply #7 on: April 28, 2010, 10:53:36 AM »
Im gonna try and swap cables this afternoon and see if that make a difference
« Reply #8 on: April 28, 2010, 01:37:49 PM »
Pics?
Ya you probably did, I was just curious if his was different...or maybe his is the one you posted for me...hell I dunno
accordepicenter
« Reply #9 on: April 28, 2010, 04:26:53 PM »
I was checking around everything appears to function the way it should... i guess i just remember the pedal being stiffer than it is
