Author Topic: Painless wastegate spring installation  (Read 27594 times)
« on: April 28, 2010, 05:27:04 PM »
I don't know how you guys install wastegate spring, but I'm in an apartment, my car is in the street and I have very basic tools.
I tried to figure out how to install the new spring in the wg and came out with this idea:
This thread is not about something extraordinaire or because I searched 2 weeks for this solution. I just wanted to share my idea...
I don't give more info on the setup cause I beleive that you are smart enough to figure out what I did  :mexi:
I also found a mega hole in my manifold like 1/4" of diameter near the wastegate I need to fix. I "fixed" it for now with manifold cement at least it will remove the smell  :?:
Re: Painless wastegate spring installation
« Reply #1 on: April 28, 2010, 05:30:13 PM »
I always find it amasing people can turbo a car without owning decent tools/equipment and no garage. I couldn't live without a nicely equiped shop anymore.
Minor Threat
« Reply #2 on: April 28, 2010, 05:33:12 PM »
Do you not own a vice?
« Reply #3 on: April 28, 2010, 05:36:00 PM »
He's canadian, what did you expect? j/k
« Reply #4 on: April 28, 2010, 05:41:30 PM »
My parents have a garage with all the tools I need, but I don't live there and it's 40 min away.
I can't do anything big in the street anyway...
Other than the timing belt I did last year  :?:
What would I do with a vise in my apartment ? :P
« Reply #5 on: April 28, 2010, 05:49:38 PM »
hold stuff
Minor Threat
« Reply #6 on: April 28, 2010, 05:54:08 PM »
hold stuff
This guy knows what's up.
bigwig
« Reply #7 on: April 28, 2010, 06:06:41 PM »
If you're poor/ghetto, walk right into Home Depot with your wastegate.  Grab a clamp.  Go find somewhere quiet.  Change your spring.  Put it back on the shelf.  With that said, C-Clamps are something you should have.  How do you depress your rear caliper without a c-clamp?
« Reply #8 on: April 28, 2010, 06:22:28 PM »
Obviously with a piece of pipe and the weight of the car...  :D
bigwig
« Reply #9 on: April 28, 2010, 06:25:30 PM »
Obviously with a socket and the weight of the car...  :D
Minor Threat
« Reply #10 on: April 28, 2010, 06:42:39 PM »
You twist them in by hand because you can't compress them like a set of front calipers?
2slow
« Reply #11 on: April 28, 2010, 09:26:20 PM »
bingo....now for the front i rarely use c clamps. i just stick a flathead between the pad and rotorand pry its alot quicker, or you can use a big plumbing wrench
« Reply #12 on: April 28, 2010, 10:32:13 PM »
Wait, my method take 1/10 of that time. You know that a wastegate is hot after couple of minutes driving around :P
The wastegate is on the car, not in my hands.
Btw, I when I need to do something "big" like changing bushing or do caliper job, I go to my parents house. My dad has for like 30k$ of tools...
I just don't want to drive 40 minutes to go there so I use my car has a vise :P
The_Fatman81
« Reply #13 on: April 28, 2010, 10:37:56 PM »
amazing use of scissor jack!! 2 thumbs up ;D
« Reply #14 on: April 28, 2010, 11:02:39 PM »
cool. but i just push down on the top and put 2 bolts in and then the rest no vice or bs like that. u got a 2bar spring in there? ???
« Reply #15 on: April 28, 2010, 11:14:17 PM »
It's a 15psi spring. I can push on top or with my hands and risk to strip 2 holes or I can take 2 minutes to install the jack and do my trick.
I'm 155lbs and you need at least 50lbs to push down that spring. It's 1/3 of my weight. I can do it by hands (without my weight), but I would need a third hand...
Huh, where is you noob post sir?
« Reply #16 on: April 28, 2010, 11:58:33 PM »
Your third hand is your cock sir
« Reply #17 on: April 29, 2010, 12:02:08 AM »
I know, but do to a complication that I don't want to talk about, I have no more finger on my cock. Yeah I know it's tragic, but shits happen!
« Reply #18 on: April 29, 2010, 01:14:26 AM »
Gain weight pussy, it's not hard to man bitch those gates back together.
« Reply #19 on: April 29, 2010, 11:21:36 AM »
Fuck that. Buy it, use it, return it. If you're scared, put tape over the ends. Otherwise they'll return almost anything if you're reasonable/forceful about it.
« Reply #20 on: April 29, 2010, 11:26:59 AM »
Be more respectful of Domtar pamphlets, I work there.
« Reply #21 on: April 29, 2010, 11:29:27 AM »
Like the idea of using your car and the ground as parts of a vise. ;D
$0 invested to get something done, works for me. :yes:
« Reply #22 on: April 29, 2010, 11:47:26 AM »
Cornwall?
« Reply #23 on: April 29, 2010, 01:51:27 PM »
Cornwall?
Kamloops
bigwig
« Reply #24 on: April 29, 2010, 05:34:19 PM »
If you're really poor, you can't afford the $6 to buy it.
« Reply #25 on: April 29, 2010, 06:18:04 PM »
shit, i got a big 8in? c-clamp from harbor freight for a dollar. look in the center isle where they have all that ship piled on the tables labeled bargain or whatever.
« Reply #26 on: April 29, 2010, 06:41:54 PM »
noob post? go f your self. i have been around since ohmt was started.
ifly87
« Reply #27 on: April 30, 2010, 03:13:46 AM »
wastegates are for pussies.
Lol...Fags
« Reply #28 on: April 30, 2010, 10:23:31 AM »
Well, even with the 13psi spring (yeah, I thought it was 15psi) the boost only reach 7psi.
I fixed a mega leak in the charge pipe but I only gain RPM on spool. Full boost at 4k instead of 5500 :P
It's accelerate "a lot" faster at low RPM, I'm sure I gained 30lbs of torque on the entire powerband by fixing that leak...
Still can't hit the boost cut tho... It stop at 7psi. I think it might be the ching chong BOV that is leaking.
It was doing the same shit on my last integra and its the same fucking setup. I doubt I installed it exactly the same way...
I'll try to pressurize it later today.
What is the best way to hook up the wastegate presure inlet? I use the nipple on the turbo. I doubt it can do a 7psi difference tho...
