Author Topic: 7 pounds on regular?  (Read 14943 times)
stealthiskey
« on: April 28, 2010, 09:55:29 PM »
Recently put my old t25 kit back on my civic.  Loaded up the old tune that I used with 93 octane, but timing was still conservative.  Have about half a tank of regular 87 octane, and it seems to be running fine at 7 pounds, maybe stronger than before, but I haven't checked the plugs yet.
Think it will work if I keep it cheap on regular?
« Last Edit: May 02, 2010, 10:28:40 AM by stealthiskey »
Re: 7 pounds on regular?
« Reply #1 on: April 28, 2010, 10:42:10 PM »
You're fine.  Be careful of quick spool setups like that at higher boost/power levels, much like nitrous the bigger the "shot" for any given octane, the higher in the rpm band it needs to "hit."
Why you ask shit like this in a non-tuning forum, which I and other people who know octane-specifics intimately rarely check, is beyond me.
« Reply #2 on: April 29, 2010, 01:10:19 AM »
Fix it for you :noel:
turbo4life
« Reply #3 on: April 29, 2010, 04:16:44 AM »
you probably be fine just retard it a degree or 2 at base  to be safe. i always ran 91 no matter what. 20cents a gallon aint much especially if gas is hella over priced..., 20 cents on the gallon dont buy you much gas anyways.
« Last Edit: April 29, 2010, 04:18:42 AM by turbo4life »
End the fake food.
« Reply #4 on: April 30, 2010, 01:30:36 AM »
Holslut time!!!!
stealthiskey
« Reply #5 on: April 30, 2010, 10:05:29 PM »
can't wait!! will prolly save that for the crx i plan to get though
« Reply #6 on: April 30, 2010, 11:59:05 PM »
Shits been shipped. I will pm track number
« Reply #7 on: May 01, 2010, 01:48:44 AM »
its like 20 cents a gallon more for 93. i dont understand why you would even risk it for 2 dollars a tank.
« Reply #8 on: May 01, 2010, 09:29:29 AM »
Why did I tune my 12.5:1 SOHC on 87?
« Reply #9 on: May 01, 2010, 09:34:44 AM »
because youre a hick.
and you probably buy used gas from the junk yard.
FUCK YOU
« Reply #10 on: May 01, 2010, 09:50:14 AM »
They sell used gas at the junkyard??
« Reply #11 on: May 01, 2010, 10:03:47 AM »
if you know someone they will give it to you around here. they drain the tanks into drums and the employees get to use it.
SDRAWKCAB
  • D series BALLA!
  • Rhino
« Reply #12 on: May 01, 2010, 02:26:11 PM »
Just imagine getting some of someones pissed off girl friend gas with go knows what in it.
I even run my goped on 93
« Reply #13 on: May 03, 2010, 03:11:59 AM »
this is true. I knew someone who did just this. said he got bad milage but it was free/dirt to use.
« Reply #14 on: May 15, 2010, 12:33:52 AM »
God why didn't you make all women in Shay Laren's image? WHY?!
BTW it will be okay. When you consider people do 400hp on 91 and barely clear 450hp with 93, you could run a t25 at 7psi with nigger piss and be fine. 87 is one reason cars in the 80's had tiny turbos and nearly 7:1 compression ratios.
« Last Edit: May 15, 2010, 12:36:12 AM by HiProfile »
