Author Topic: New Innovative product  (Read 8947 times)
hatchboy
  • Bombs Over Baghdad
« on: May 08, 2010, 11:07:41 AM »
http://www.ot-2.com/
Discuss?
I don't see how accurate it could be just coming through your obd2 port.
Re: New Innovative product
« Reply #1 on: May 08, 2010, 11:16:59 AM »
Obd2 ports carry everything you need to know. Very accurate IMO. I'm just not a fan of gay iPhones.
The_Fatman81
« Reply #2 on: May 08, 2010, 11:33:24 AM »
I liked it better when i could hook up my gameboy advance instead! :)
SDRAWKCAB
  • D series BALLA!
  • Rhino
« Reply #3 on: May 08, 2010, 12:38:13 PM »
Wireless gauges sound sketchy.
the app is free and does the gay dyno fuel thing.
so your paying almost 200 bucks for a obd2 data logger and a obd2 scaner only a complete tool bag would think this is a good idea.
« Reply #4 on: May 08, 2010, 12:59:45 PM »
Who here actually has anything that's still obd2?
« Reply #5 on: May 08, 2010, 02:52:27 PM »
Me!
For now...er,,,more likely forever since I cannot get motivated to do anything to this pile of fuck.
« Reply #6 on: May 08, 2010, 02:58:14 PM »
obd2 port= buffered by the ecu, not "real" readings, not as acurate.
« Reply #7 on: May 08, 2010, 03:48:08 PM »
obd2 so I dont care
« Reply #8 on: May 08, 2010, 04:22:15 PM »
Nothing wrong with bluetooth/wifi wireless...  It's digital and not analog wireless so interference wouldn't be an issue, it'd either get the correct data or none at all.
But yeah, waste of money.  It is marketed towards the trendy apple fags that like paying for overpriced stuff, though.
I wish I had the technical know-how to make some sort of ECU wireless data-transmitting device, as I've considered an app like this before, except for Android and/or Linux (for carpcs).
« Reply #9 on: May 08, 2010, 09:46:16 PM »
I'm converting an 80s car to OBD2.
So it's slowed down a couple nanoseconds...?
« Reply #10 on: May 08, 2010, 10:27:29 PM »
Innovate not Innovative  you fucking illiterate bastard.
« Reply #11 on: May 08, 2010, 10:58:14 PM »
Innovative motor mount. Innovate motorsports.
Looks cool, but  expensive for a gadget...
hatchboy
« Reply #12 on: May 09, 2010, 12:12:57 AM »
I really don't care if i spelt it right. You all apparently knew what i was talking about.
In-fact, i am not even going to modify the post.
« Reply #13 on: May 09, 2010, 01:02:41 AM »
anyone with a late model mustang/f body? theres more cars that use OBD2 tuning spftware then not. its obviously not catered to POS hondas
« Reply #14 on: May 09, 2010, 01:21:14 AM »
Anyone trying to make real power, easily.
« Reply #15 on: May 09, 2010, 02:10:56 AM »
Are you saying the data stream is 100% real world live numbers? You dont prefer a seperate set of senders/gauges? I do.
« Reply #16 on: May 09, 2010, 08:42:27 AM »
Show me a sender/gauge combo that reacts as quickly as a 16Mhz ECU, much less a 200+ Mhz one as some of the new cars have.
« Reply #17 on: May 09, 2010, 12:57:51 PM »
Yes but I was told by the guys who wrote my programs for my 6.0l that to get that amount of power from the stock setup the ecu basically gets lied to, if you run the obd2 port gauges they will lie to you. Maybe my info was incorrect?
« Reply #18 on: May 09, 2010, 01:34:43 PM »
The guy's who sent you some programs they very much didn't write (they might have piddled with an editor someone else wrote with very limited knowledge of the actual program itself - they are kicked inside docs from the OEMs and there is NO reversal taking place among the domestic ECUs) have about as much clue about what's going on as the #2 distributor of the same brand handhelds, who also fucked up a simple tune on Corey's car by making a bunch of n00b ass mistakes.
To get "that amount" of power from the stock setup, your ECU is reprogrammed for different injector timing, injector duration, and fuel pressures.  Short of one of the piggybacks, no, your ECU is not being lied to.  As far as "OBD2 port gauges" there are a number of ways they could be wrong.  If you are logging off of your handheld they default to a delayed feedback but can be changed to instantaneous.  Second, if the gauge is a generic one meant to read a raw hex value from RAM which is then interpreted by the gauge, if you rescale said parameter inside the ECU's code then suddenly the gauge is wrong because it doesn't know what the ECU is doing.
« Reply #19 on: May 09, 2010, 11:15:11 PM »
I said here as in RHMT not here as in the earth you fuckheads.
« Reply #20 on: May 10, 2010, 12:08:15 AM »
well look what I learned today  :P
« Reply #21 on: May 10, 2010, 12:33:03 AM »
And you got your answer.  I swear, you French-Canadians get awful emotional.
