Author Topic: what head bolts?  (Read 23859 times)
johntsi
what head bolts?
« on: April 03, 2009, 02:39:26 PM »
im gettin close but my bolts wont work i have a y7 head z6 block and y7 head bolts .. what do i need z6 bolts?
Re: what head bolts?
« Reply #1 on: April 03, 2009, 04:43:15 PM »
« Reply #2 on: April 04, 2009, 10:51:14 AM »
A mixed set of Z6 bolts with two OBD2 Y7/8 bolts for the back corners.
johntsi
« Reply #3 on: April 04, 2009, 01:00:40 PM »
i bought a set of z6 arps and the back left looked a little long what would be the issue?
« Last Edit: April 04, 2009, 01:27:39 PM by johntsi »
« Reply #4 on: April 04, 2009, 02:56:12 PM »
Yes sir.  The head bosses are elevated.
johntsi
« Reply #5 on: April 06, 2009, 11:41:15 AM »
so should i just use a stock head bolt there?  :-\
« Reply #6 on: April 06, 2009, 11:46:08 AM »
What?  No
johntsi
« Reply #7 on: April 06, 2009, 11:46:59 AM »
well what the hell then buy a set of y7 studs to use one?
« Reply #8 on: April 06, 2009, 11:50:17 AM »
johntsi
« Reply #9 on: April 06, 2009, 11:54:49 AM »
even the kit from lighening motorsports only comes with one different stud though
walter
johntsi
« Reply #11 on: April 06, 2009, 03:41:46 PM »
k so i took the back head stud out and the stud bottoms out and the threads dont go in past the head what if i just use another hardened washer? torque it down and check it in a couple of days
« Reply #12 on: April 06, 2009, 03:51:20 PM »
Try it!  Sounds like it will work...
