Author Topic: cdm tig?  (Read 39721 times)
Re: cdm tig?
« Reply #30 on: June 03, 2010, 01:05:46 AM »
it says it is adjustable but cant find any thing bout how much and on the duty cycle info it say60hz,50% cleaning. and i looked for a long time to find out what rang you can adjust but cant find any thing.
Re: cdm tig?
« Reply #31 on: June 03, 2010, 01:17:21 AM »
Well I wouldn't worry about it too much then, as long as you can adjust it it will be plenty fine for manual welding.
Re: cdm tig?
« Reply #32 on: June 03, 2010, 01:44:11 AM »
i think you can only change it for stick welding...  ::)maybe josh will pop in and tell use more abou it as he used to have this welder. but to me that sucks.
Re: cdm tig?
« Reply #33 on: June 03, 2010, 01:47:27 AM »
Personally i would just get a sync 200 and call it a day. mine has been a beast and no issues sense i got it in 06'. i think i have 100hrs on it or something like that.
Re: cdm tig?
« Reply #34 on: June 03, 2010, 02:06:49 AM »
i would like to get a inverter for greater balance/frec. control as well as power consumtion. and i dont like that the syncowave has automatic post flow=wast of gas
Re: cdm tig?
« Reply #35 on: June 03, 2010, 11:06:52 AM »
Once upon a time I worked in an aluminum fab shop, we had syncs and dynasty's. It was always a fight to use the dynasty's and this was just for production aluminum welding, nothing fancy. The biggest reason was frequency control, once you have had it, it is hard to live with out.
Also 100hrs on a machine is nothing, at the above fab shop with two 10hr shifts, the production crew would have 100hrs arc on time a month on a machine. Some of our older sync machines had over 15,000 arc on hrs on them. The oldest Dynasty machine had about 10,000hrs. Some of the early 300dx's had some control board issues, but over all they were all dead reliable machines.
One thing to note about the post flow on the sync is that you can manually over ride that feature.
The other thing is that the sync is a power hog, at 200A it draws over 60Amps, All 6 of my welder plugs are on 40amp breakers, and typical welding outlets are only 50amp outlets.
I own a 200dx, the big deciding factors for me were:
- Frequency control, being able to direct the arc to the root, and still be able to reduce penetration for thin aluminum is a really nice feature. Also high frequency and low balance, really busts shit up, you can even weld through anodizing.
- Size, I can carry the 200dx in one hand with the handle. I have taken it over to numerous friends places, and to odd jobs, and because it will work on just about any voltage input it is easy to do. This wasn't my plan when I bought it, when I bought it I had a basement (lots of pics of that fab floating around) and a very small single car garage, so I needed to easily be able to carry it up and down the stairs.
- Power consumption, like I said above the sync200 pulls over 60 amps flat out. At 150amps output it draws 54amps @ 230V, the Dynasty at 150amps output draws 16amps @230v. It is easy to trip breakers with the sync, almost impossible with the Dynasty.
- Adjustable wave form. I really like square wave as I spent a few years doing production and I still have a tendency to want to slam the pedal down and go. I also like the triangle wave for thin shit.
- High Frequency only at the arc start, I haven't had much issue with running continuous HF on the syncs, but all the same I would just as soon have it shut off after the arc has started. Keeps the shop radio happy, and playing music vs static...  :D
Re: cdm tig?
« Reply #36 on: June 03, 2010, 07:26:15 PM »
I own a 200dx, but I am looking to upgrade, Highroller54 is going to buy this one  :yes:
 ;D
Re: cdm tig?
« Reply #37 on: June 03, 2010, 08:56:03 PM »
I own a 200dx, but I am looking to upgrade to Passengers 300dx, then Passenger will upgrade to a 350dx or a 700dx and Highroller54 is going to buy this one  :yes:
 ;D
Fixed for accuracy.
Random Hero
Re: cdm tig?
« Reply #38 on: June 04, 2010, 01:15:57 AM »
it does have full balance and freq control, its really easy to use you just need to review the laminated 1 page sheet that comes with the welder, just like i said alex, I still have that sheet!
Re: cdm tig?
« Reply #39 on: June 04, 2010, 01:31:37 AM »
i will give you a call tomarow so we can talk.. :noel:
narfdanarf
Re: cdm tig?
« Reply #40 on: June 06, 2010, 09:16:32 PM »
you don't have to leave it on auto genius.
Re: cdm tig?
« Reply #41 on: June 07, 2010, 01:24:47 AM »
"auto" to me means not user adjustable.
narfdanarf
Re: cdm tig?
« Reply #42 on: June 07, 2010, 07:02:21 PM »
it is adjustable. Truthfully though I find the auto post flow to be pretty spot on most of the time, unless I'm doing tacks, in which case I will turn it to manual and turn the post flow way down.
Re: cdm tig?
« Reply #43 on: June 07, 2010, 11:21:04 PM »
In automatic mode, this is true, Slim Shady.
Re: cdm tig?
« Reply #44 on: June 14, 2010, 12:58:17 AM »
i think im going to get a dynasty 200 or maybe a 350 if i can find a good deal on one. i like the wave control on the dynastys.
Re: cdm tig?
« Reply #45 on: July 23, 2010, 05:57:28 PM »
If you haven't already picked one up:
http://vancouver.en.craigslist.ca/van/tls/1852264448.html
$2500 for a 200dx is cheap.
Re: cdm tig?
« Reply #46 on: July 23, 2010, 06:26:49 PM »
If I remember right, dont you have to turn it off, hold some button, turn it on then change it.  Kind of obnoxious.  I just leave it auto.  Works just fine.  Meh. I'm lazy though.
Re: cdm tig?
« Reply #47 on: July 27, 2010, 12:53:12 AM »
i ended up getting a syncrowave 200dx for a smokin deal.
Re: cdm tig?
« Reply #48 on: July 27, 2010, 10:13:51 AM »
You wont.  I still love mine.
Re: cdm tig?
« Reply #49 on: July 27, 2010, 12:05:45 PM »
The syncrowave is a very good machine, I'm sure it'll treat you well.
Re: cdm tig?
« Reply #50 on: July 27, 2010, 08:43:34 PM »
Every CDM TIG I know of has died, with the possible exception of hotrex's which he was using as light duty plasma cutter.
