Author Topic: TPS wiring diagram - RSX  (Read 10629 times)
walter
« on: June 02, 2010, 12:05:11 PM »
what title says, does someone have TPS diagrama of RSX-S? i means 3 wires, what is signal,etc,etc.
Im installing a ITB with a friend of mine in his Civic EP3 K20A2 (same as RSX_S) and we have some problems with TPS wiring , i just need to connect it, i know we will have to use alpha mode but just ill need tps diagram!
Thanks!
Re: TPS wiring diagram - RSX
« Reply #1 on: June 02, 2010, 12:14:07 PM »
Did you look in the harness connector?
They usually have symbols that correspond to Ground, V in, and signal. ;D
« Reply #2 on: June 02, 2010, 12:32:29 PM »
Vcc = +5Vref
SG = Sensor Ground
TPS = TPS signal
walter
« Reply #3 on: June 02, 2010, 12:42:55 PM »
thank you very much!!!!  :)
« Reply #4 on: June 07, 2010, 12:49:19 PM »
I think I'll be getting that mitchel thing now. Alldata has shit for wiring diagrams in every case I've seen.
« Reply #5 on: June 07, 2010, 12:53:34 PM »
Really?  Because everyone tells me Alldata's wiring diagrams are better.  I have the pass to a dealer's Alldata online that I use in the field if I need an odd diagram, it seemed to me that everything was broken down into sub-system diagrams which I find to be of limited use for what I do - hell only used it once for stereo and climate control wiring on a G35 as my laptop doesn't have a current set of data discs.
« Reply #6 on: June 07, 2010, 07:16:31 PM »
I haven't ever used Mitchell, but I must say that the color coded schematics would be nice.
Alldata has worked just fine for most of the crap I have dealt with.  Not like I have a choice in the matter though.
« Reply #7 on: June 07, 2010, 07:23:55 PM »
Not everything is color coded in Mitchell, most of the early 90s and prior cars are the crappy scans we all know and love.
walter
« Reply #8 on: June 07, 2010, 07:25:57 PM »
walter
« Reply #9 on: June 07, 2010, 07:27:37 PM »
btw, i use Autodata and Vivid Workshopdata but they are shit for japan cars..mostly for european shit cars works good.
« Reply #10 on: June 07, 2010, 07:46:56 PM »
this was how i was able to figure out mine for the ms
The easiest way to check a TPS is to unplug it and put an ohmmeter on its pins. Observe the resistance as the throttle opens and closes. Each pair of pins will behave differently:
The resistance between the VREF and ground pins will remain constant.
The resistance between the ground and signal pins will be low with the throttle closed and high with the throttle wide open.
The resistance between the VREF and signal pins will be high with the throttle closed and low with the throttle wide open.
