Author Topic: stock lsd for a ls trans?  (Read 11543 times)
« on: June 08, 2010, 02:33:12 PM »
need to put a lsd into a ls trans, can a type r or jdm b16 lsd be put into a ls trans WITHOUT changing the final drive ratio?
Re: stock lsd for a ls trans?
« Reply #1 on: June 08, 2010, 09:39:59 PM »
B16 is the same diff and FD bolt pattern as LS.   If OEM "acorn" diff, you know they aren't very robust?
« Reply #2 on: June 08, 2010, 10:11:20 PM »
I do know that BUT Is the factory b16a lsd diff swapable for a open diff b16a? I have read that you cannot interchange the two  ??? different ring gear ***I THINK*** between the two?
Were not talking any kind of power or traction here a oem diff would work just fine  ;)
« Reply #3 on: June 09, 2010, 09:51:41 AM »
Hrm, you're right I think the ring gear bolt pattern is different.  Let me ask.
« Reply #4 on: June 09, 2010, 01:46:02 PM »
I am pretty sure the b16 viscous pile of fuck shares the same smaller bolt pattern with its B16/LS open differential cousin.  i have only seen one in person, and that has been about 3 years ago.
As far as i know, the ITR/GSR differentials are the only ones with the larger bolt pattern.
« Reply #5 on: June 09, 2010, 01:49:01 PM »
so the b16 is viscous? not a torsen like my itr?
« Reply #6 on: June 09, 2010, 07:05:49 PM »
I am about 99% sure that is the case.
« Reply #7 on: June 09, 2010, 08:49:48 PM »
so the b16 is crap? not a torsen like my itr?
Confirmed.
« Reply #8 on: June 10, 2010, 12:13:44 AM »
hmmmm, me thinks a obx or something will be the way to go then, thanks!
« Reply #9 on: June 10, 2010, 02:00:50 AM »
mfactory
« Reply #10 on: June 10, 2010, 05:58:56 PM »
