Author Topic: My tach be jumpin  (Read 12451 times)
My tach be jumpin
« on: June 12, 2010, 10:35:03 PM »
Srsly.
I've gone a couple weeks without issue in my swap so I guess I'm due for a problem.
I first noticed it a few days back.  Around 4500rpm and up, the tach would jump back and forth between 4000 and 4500.
Next few days didn't do it (or I didn't catch it).
Today when I was driving, first gear, it was doing the same thing between 500-1500rpm, and when I was idling the tach would be pegged at 0rpm but it wouldn't jump if I gave it gas.
1 - Distributor gone wild?
2 - Save to drive with it acting like this?
Re: My tach be jumpin
« Reply #1 on: June 13, 2010, 01:57:20 AM »
igniter or ALT, 4000-4500 and up jumping = my igniter was when.
Swapped it out with a beefier Accord unit, no more issues.
« Reply #2 on: June 13, 2010, 03:12:12 AM »
Another fine post.   :yes:  :noel:  8)  :D  ;)
« Reply #3 on: June 13, 2010, 04:02:34 AM »
Thanks I think I have one somewhere.
« Reply #4 on: June 13, 2010, 04:42:05 AM »
D series obd1 units interchange also so if you have a spare one jack it. If not part store ones are cheap and work pretty well havent seen one fail in a short period of time yet.
« Reply #5 on: June 13, 2010, 11:40:55 PM »
Replaced the ICM with a fresh vato zone one.
Still acts weird.  Will be fine most of the time, but then goes retarded like this:
video-2010-06-13-19-24-20
Engine running but showing 0rpm?  Usually it's at about 500-750.  I haven't noticed the tach jumping but I'm usually watching the road.
Speedo seems to display the correct speed for the RPM though.  Even at idle.
« Last Edit: June 13, 2010, 11:44:03 PM by Jorsher »
« Reply #6 on: June 14, 2010, 12:09:03 AM »
Take out the cluster
Remove tach, should be a few screws on back of cluster
Reflow solder joints. I recently had to do this on an accord speedo.
« Reply #7 on: June 14, 2010, 12:10:39 AM »
So, ICM was probably fine?
Guess it's a good excuse to buy a decent soldering iron.
« Reply #8 on: June 14, 2010, 12:14:46 AM »
Yea this was for a jumpy speedo, not a tach. I don't see why it couldn't happen to a tach tho if you've already pursued other options. It's easy enough to do, give it a shot.
No need for a good soldering iron, a $10-15 unit will work.
« Reply #9 on: June 14, 2010, 01:10:43 AM »
harbor freight has some decent ones for under $10 that work great if you keep them really clean, and don't let friends borrow them (related to quality of friends, not quality of the iron or my multimeter)
« Reply #10 on: June 14, 2010, 03:32:22 AM »
People with aftermarket tachs that still have a stock tach in their dash piss me off
« Reply #11 on: June 14, 2010, 09:42:39 AM »
Where'd that come from? :P
Stock tach here.  Wish I kept the JDMZ one for the 9000rpm tach, but CEL @ 8500rpm works just as well.
« Reply #12 on: June 16, 2010, 03:47:00 AM »
In case you were considering Phate's fail option.
« Reply #13 on: June 16, 2010, 04:06:28 AM »
You trust what is i the dash???????
My D15B7 had a 7100 redline according to the OEM tach......600 rpm high
