Author Topic: lm-2 hooked to ecu  (Read 7910 times)
si 1
lm-2 hooked to ecu
« on: June 13, 2010, 01:59:58 PM »
Alright just need a yes or no if i got this right. Trying to hook this lm-2 to the ecu for data-logging on a p28.
1. Is this the harness i need to analog out for the lm-2
LM-2 Analog I/O Cable
https://www.upscaleautomotive.com/popup.aspx?src=images/Product/large/innovate3811.jpg
2. Would i hook it up the same way as it shows to hook the lc-1 up
http://www.lukekailburn.com/lc1.html
3. Reset my analog out put to
0.1v = 7.35 afr
3.25v = 22 afr
Thanks for any help you guys can give me iv been researching this as much as i can just need a better idea before i buy the harness.
Re: lm-2 hooked to ecu
« Reply #1 on: June 13, 2010, 03:39:04 PM »
Eh.
There are two analog ouputs, you want to hook the (+) to whichever pin you are logging from.  Connect the (-) to the thermostat housing ground.
I like resolution, and the extreme ends of the spectrum that Innovate WBs read is pretty useless.  I set 10-20 AFR to 0-5v, unless dealing with an unmodified pin D14 and then I'll probably leave it that way anyhow.  Being able to read a high 16 is fine for the intents and purposes of tuning a car.
si 1
« Reply #2 on: June 13, 2010, 09:45:48 PM »
You might hate me but what do i need to do to modify the d14pin. thanks for the help again JD i dont think very many people use the lm2.
« Reply #3 on: June 13, 2010, 10:55:50 PM »
The pgmfi.org wiki has Mark Lamond's notes on how to modify the D14/stock O2 circuitry to accept a full 5 volts.  I've only followed it once, and anything I told you would be a cut and paste of his work, anyway.
