Author Topic: Anyone use an electric solder sucker before?  (Read 7468 times)
El Beefo
  • tongue punch my fart box
« on: June 20, 2010, 04:41:06 PM »
Curious about buying one. Anyone have experience w/ them. pros cons? I like my solder braid and $10 radio shack manual pump but i think its time to upgrade. Id love a hakko but i dont do enough soldering to warrent spending 150 plus.
« Last Edit: June 21, 2010, 07:44:12 PM by El Beefo »
Re: Anyone use an electronic solder sucker before?
« Reply #1 on: June 20, 2010, 08:42:07 PM »
I wouldn't call that electronic, exactly.
The whole load and pushbutton stuff annoys me, I've tried with the non-heated solder suckers (you flow with a seperate iron on the top of the board) and don't like them.  Adam Hopkins used one when he came to visit and did a masterful job with one of those, so there is a viable method there I just don't use it.
Should work better than the standalone sucker that needs a seperate iron to heat, not having to juggle two tools negates 90% of my problem with "that design."  Just remember to keep the tip super clean, and tin it with a little solder before you begin, and it should work pretty well.
SgtB
« Reply #2 on: June 21, 2010, 06:30:07 PM »
The only problem I see is the release button being so far back on the handle. It may be tricky to hit the plunger on smaller stuff. Looks neat though. I use a plunger tool to de-solder and had no idea they came as a single unit. I use a huge plastic one though. It pulls a lot more volume so it's much easier to clean the joint out.
Re: Anyone use an electric solder sucker before?
« Reply #3 on: June 22, 2010, 03:13:31 AM »
get a desoldering station with a vacuum pump and be done.
