Author Topic: What are my options?  (Read 10849 times)
2slow
« on: June 24, 2010, 05:23:59 AM »
I want to stiffen up my motor mounts, but  I dont want it too stiff. I know the window weld trick, but i personally never rode in a car with filled mounts. I'm used to shitty rattling hondas. I just dont want to make the car anymore shittier/rattling than I need too. It's very unlikely the car will ever see a track or slicks, so i just wanna stiffen it up alittle. Any input will be cool.
Re: What are my options?
« Reply #1 on: June 24, 2010, 05:51:14 AM »
good condition oem used mounts
« Reply #2 on: June 24, 2010, 07:12:49 AM »
Buy a Buick.
« Reply #3 on: June 24, 2010, 08:01:55 AM »
+1 on GOOD stock mounts. Make sure you have the front torque mounts too if it's an eg/ek.
« Reply #4 on: June 27, 2010, 04:20:33 PM »
Get an extra set of mounts, fill 'em.  Then install one at a time.  You can play around with them untill you get it just right.  And it's reversible with an extra set...
« Reply #5 on: June 27, 2010, 04:43:03 PM »
Or just fill the mount that acts as the biggest lever arm to engine when it is trying to rotate about the crank axis first.
« Reply #6 on: June 27, 2010, 05:41:32 PM »
I have always had filled mounts and never thought they vibrated.
« Reply #7 on: June 27, 2010, 05:46:50 PM »
All five of my mounts are filled and at low revs. w/o load there is some vibration resignating
(sp)  through the chassis.
 But it is tolerable. ;D
« Reply #8 on: June 27, 2010, 08:05:29 PM »
All my cars rattle no matter what mounts. Guess the one bolt holding the dash style has its down falls.
