Author Topic: D16 with GT35 turbo?  (Read 20715 times)
walter
« on: June 24, 2010, 09:19:12 AM »
hi,im looking for a new setup very soon, just will runs with vitara/eagle , mild ported/polished head, maybe aftermarket cam , not sure if Gt35 BB will goes good, just i can get diretly from my Chinese supplier (yes, chinese  supplier) for a good price, this are the specs of turbo:
Trim-T   A/R -T   Trim-C   A/R- C
84            0,63             56             0,7
goal around 300-350whp.
besides, what manifold do i can make for this setup? i'll get pipes from another Chinese supplier for stainless pipe/tubing  :noel: just im worried abit about engine bay of my civic 90.
what do you guys think?
lmk!
Re: D16 with GT35 turbo?
« Reply #1 on: June 24, 2010, 09:19:53 AM »
 :-X
walter
« Reply #2 on: June 24, 2010, 09:32:29 AM »
that's for my english or for turbo?  ;D
what turbo do you would recommend for this setup?
MAJORAHOLE
  • fuckin C-unt
« Reply #3 on: June 24, 2010, 09:38:21 AM »
i thought the chineese made journal bearing turbos only?
walter
« Reply #4 on: June 24, 2010, 09:41:29 AM »
this isnt a ebay seller, i got directly from china, they make BB and journal bearing turbos.
« Reply #5 on: June 24, 2010, 10:34:16 AM »
holy shit I can't wait for $100 ball bearing ebay turbos.
« Reply #6 on: June 24, 2010, 12:23:28 PM »
Did you know you can make your own roller/ball bearing turbo form a journal bearing with a drill press and an ability to find roller bearings by deminsions using a bearing buyer's guide.
And if done right for less than $20, I had an old turbo rebuilder explain it to me about 15 yrs. ago. It did not seem too difficult.
« Reply #8 on: June 24, 2010, 02:47:18 PM »
Never gave it any thought to be honest, although it seems almost obvious.  You'd basically need the bearing width, the inside diameter for the shaft, and the outer diameter (of where the journal bearing sat before).  Then look up a set of ball bearings that take an external oil supply that are within those dimensions.  Awesome.
« Reply #9 on: June 24, 2010, 03:21:16 PM »
Or just get a sealed bearing similar to what is used alternators but take the seals off and the oil will flow around and throught the bearing. ;)
« Reply #10 on: June 24, 2010, 05:11:21 PM »
Rossnoggin rebuilt a GT40 with some bearings he cross referrence to a Boca catalog.
« Reply #11 on: June 24, 2010, 05:14:52 PM »
um holset!
« Reply #12 on: June 24, 2010, 05:15:50 PM »
um holset!
I wonder if he can just get a CDM copy of a Holset?  :?:
« Reply #13 on: June 24, 2010, 06:58:00 PM »
Would the bearing have to be pressed onto the shaft? The shaft spinning inside the bearing race would kind of defeat the purpose wouldn't it?
walter
« Reply #14 on: June 24, 2010, 07:06:54 PM »
« Reply #15 on: June 24, 2010, 10:13:51 PM »
« Reply #16 on: June 24, 2010, 10:15:28 PM »
Not always you could have a 0.001" to 0.003" tolerance to acount for for operating temps. ;D
TTC
« Reply #17 on: July 05, 2010, 10:46:59 AM »
I looked into it and started to change a 14b to ball bearing. The issue was finding the correct dimensions locally and also ensuring that the bearing could spin like 100k rpm and not splode. IIRC garett bearings have some sort of side load design into them that most bearings don't. I forget the technical term.
« Reply #18 on: July 05, 2010, 10:54:42 AM »
Thrust
« Reply #19 on: July 05, 2010, 11:00:07 AM »
um holset!
great for 300-350 and beyond
