Author Topic: Which valves to use for deez?  (Read 27911 times)
« on: June 25, 2010, 12:10:32 PM »
Same shit as the LS thread.  JD, in your research what have you found out as far as D valves go?  Anything larger swappable that's OEM?
Re: Which valves to use for deez?
« Reply #1 on: June 25, 2010, 04:14:21 PM »
Rule of thumb is anything bigger than 0.5mm oversized needs a new seat.  For a D, I'd go bigger with the intakes and let the exhaust figure it's own way out of the chamber.
« Reply #2 on: June 25, 2010, 11:36:15 PM »
I'd do the opposite.
Going bigger on the intake side just means the outer edge is shrouded by the cylinder wall more.
« Reply #3 on: June 25, 2010, 11:44:29 PM »
Couldn't you just cut a little on the top cylinder to help with flow?
Sort of like what they do for SBC or SBF when they are using 2.02 or 2.06" intake valves on a small than 4.00 bore. :-\
« Reply #4 on: June 26, 2010, 02:01:43 AM »
steel block vs thin steel liners. Now if the block is sleeved out to 78/79 mm, then 1mm over on the valves is useful.
« Reply #5 on: June 26, 2010, 06:50:33 AM »
Yes, but on which head, Bone?  There are two different valve spacings in the proper D-series families.
« Reply #6 on: June 26, 2010, 12:44:18 PM »
More info on this valve spacing please.  ;D
« Reply #7 on: June 26, 2010, 03:55:30 PM »
Have you never looked at an A6/B1/B2//B head compared to a Z1/Z6/Y5/Y7/Y8 head?
The valve spacing difference is quite apparent.
« Reply #8 on: June 26, 2010, 04:06:10 PM »
I look at the B7 an B8 heads but I figured the valve spacing would be the same if you use z6 valves and seats. :-\
Never really dove into the spacing and shrouding issue.
Maybe I will look at this more. ;D
« Reply #9 on: June 26, 2010, 04:10:34 PM »
Valve spacing is not a characteristic determined by the the valves and seats, but rather the casting itself.
« Reply #10 on: June 26, 2010, 04:13:53 PM »
I usually look at the valve edge to edge spacing, and the valve edge to cylinder wall issue. I have had no need to look at the valve center to valve center, until now.
« Reply #11 on: September 30, 2010, 03:05:35 PM »
Bump because, while neither Russ nor I give a shit, Staley Dan is whining about this to me basically all the goddamn time.
FYI F22/F23 intakes are 34mm, but 2.5mm short.
« Reply #12 on: September 30, 2010, 03:30:08 PM »
I see what he is saying.
ENGINE CODE   V-TEC   D16Y8 V-TEC
INTAKE                PV4370HP-C      1.22 X 5.5MM X 4.66 X 1G
EXHAUST   PV4372HP-C   1.06 X 5.5MM X 4.56 X 1G
ENGINE CODE   F-23A   A4-A5-A7-VTEC
INTAKE               PV4573               1.33 X 5.5 M X 4.56 X 1G
INTAKE      P4378HP-C   1.37 X 5.5MM X 4.56 X 1G
Not worried yet  ;D
I may still have another cheaper route.  ;D
« Reply #13 on: September 30, 2010, 07:53:10 PM »
i lol'd
well played sir
Subaru valves are longer, slightly thicker, and 32mm.  Make it happen.
« Reply #14 on: September 30, 2010, 09:07:20 PM »
i lol'd
well played sir
I was find those to be too thick.
« Reply #15 on: September 30, 2010, 10:43:25 PM »
How thick?  Guide sizes can be manipulated, although it gets to be pricey.
« Reply #16 on: September 30, 2010, 11:42:03 PM »
What is the installed height on D16 springs?  Diameter where retainer sits?
« Reply #17 on: October 01, 2010, 12:10:28 AM »
O K
« Reply #18 on: October 01, 2010, 12:26:37 AM »
Give me some dimensions.  Dumbestic valvetrain parts are listed by dimension.
« Reply #19 on: October 01, 2010, 08:19:15 AM »
D16=>5.5mm
Subaru=>8.0mm  I only have listings of 76 to 05 and not all of the EJ family.  :-\
VOLKSWAGON   86-92         2109CC
INTAKE      P3467   1.57 X 8MM X 4.81 X 3G <--- too many grooves and too big of valves
EXHAUST   P3466   1.33 X 9MM X 4.83 X 3G <--- too many grooves and too big of valves
PONTIAC   77-80          151 CC (ironduke w/ non- crossflow heads)
IN  79-80   P3063   1.72 X 11/32 X 4.66 X 2G <--- too many grooves and too big of valves but usually super cheap.
EX  79-80   P3367   1.50 X 11/32 X 4.62 X 2G <--- too many grooves and too big of valves but usually super cheap.
OLDSMOBILE   75-82          260 C.I.
EXHAUST   P2946   1.30 X 11/32 X 4.68 X 1G  <-- a little too big
OLDSMOBILE   80-90         307 C.I.
INTAKE      P3205   1.75 X 11/32 X 4.66 X 1G
EXHAUST   P2993   1.50 X 11/32 X 4.68 X 1G
There is a lot Olds engines that have the right length valves and single groove on the stems.
The stem dia. are around 8 to 9mm and have 1.5" to 2.0" heads.
Which would not fit very well in 4-valve D-series heads.
NISSAN   82-83         1488CC
INTAKE     P3279   1.45 X 7MM X 4.67 X 1G <-- Possibly a good candidate if you modify valve guides
EXHAUST   P3278   1.18 X 7MM X 4.64 X 1G <-- Possibly a good candidate if you modify valve guides
NISSAN   83-84         1488CC Turbo
INTAKE     P3280   1.45 X 7MM X 4.70 X 1G <-- Possibly a good candidate if you modify valve guides
EXHAUST   P3297   1.22 X 7MM X 4.71 X 1G <-- Possibly a good candidate if you modify valve guides
MAZDA   94-04           2994 CC Ford Built
INTAKE  94-99   P3485   1.66 X 8MM X 4.610 X 3G <-- a little short and the head are a bit big.
INTAKE  00-04   PV4598   1.66 X 7MM X 4.630 X 3G <-- a little short and the head are a bit big.
EXHAUST 00-04   PV4599   1.37 X 7MM X 4.610 X 3G <-- a little tall and the head are a bit big.
EXHAUST 94-99   P3484   1.37 X 8MM X 4.610 X 3G <-- a little tall and the head are a bit big.
GM   85-88           1.0 L Sprint
INTAKE     P3808   1.41 X 7MM X 4.55 X 1G <-- a little short and the head are a bit big.
EXHAUST   P3807   1.18 X 7MM X 4.51 X 1G <-- a little tall but a possible candidate
GM   83-86          2.0L Brazillian built (Opel)
INTAKE     P3175   1.60 X 8MM X 4.70 X 1G<-- Possibly a good candidate if you modify valve guides
EXHAUST   P3174   1.37 X 8MM X 4.72 X 1G<-- Possibly a good candidate if you modify valve guides
I have no spring install height ATM but I can dig up some later. ;D
« Reply #20 on: October 01, 2010, 09:52:29 AM »
You know, the idea I had about machining down F22/F23 valves that Staley Dan stole from me before I came up with it might be the way to fly.  If you pay close attention to coil bind vs cam lift vs seat pressure, or hell knock a tenth out of the spring seat on the top of the head, it makes a lot of sense.
You may all thank me now, starting with Staleard.
« Reply #21 on: October 01, 2010, 10:06:08 AM »
How does this address the 2.54mm shortness in respect of the rocker to valve geometry?  :-\
« Reply #22 on: October 01, 2010, 10:19:18 AM »
Boo hoo it rattles?
« Reply #24 on: October 01, 2010, 03:19:25 PM »
Or homemade lash screws.  Stick longer lash screw in the same vice drill valve grinder and grind it roundish and smooth.
« Reply #25 on: October 01, 2010, 08:18:09 PM »
2.34 you never do any of this.
« Reply #26 on: October 01, 2010, 08:32:53 PM »
I may at some point in order to make the point that free (or cheap) is a quality overcoming many faults, which was the original premise of hotrodding back when Men made their own shit and there was no Summit catalog.
Right now, $13 os so per valve is damn attractive.
