Author Topic: Daily EG Civic Quiz.  (Read 26763 times)
« on: April 06, 2009, 08:32:28 AM »
1) While having different part numbers from honda, the 2 door coupe and 3 door hatchback windshields are interchangable on 92-95 civics.
True
False
2) The starter's 12v wire comes directly from the battery, and not from the fuse box or another source.
True
False
3) Looking at the white female plug on top of the fuel pump, the two connections go as follows in stock configuration.
A) Right connection is power, left connection is ground.
B) Right connection is ground, left is power.
*Extra Credit*
What is the name of Joseph Davis' offspring?
« Last Edit: April 06, 2009, 08:36:04 AM by Stealthmode »
Re: Daily EG Civic Quiz.
« Reply #1 on: April 06, 2009, 11:09:58 AM »
True
MantisX
« Reply #2 on: April 06, 2009, 04:20:52 PM »
True
« Reply #3 on: April 06, 2009, 04:38:13 PM »
1.= true
2. is s true and false it goes to the fuesebox then to starter but its the same wire.
3. ?
bonus i dunno but she is cute watch her carfully JD
« Reply #4 on: April 06, 2009, 05:50:50 PM »
Extra Credit Question.
Where are the SAE threads in a Honda Civic?
« Reply #5 on: April 06, 2009, 10:46:14 PM »
True
Well too fuckin bad I cracked the 2dr one at the junk today. The mexicans were all watching my choke wire and seatbelt skills too.  :'(
Not sure how that's possible. There's two positions in the fusebox. One I believe feeds the general wire harness to the cabin, and the other goes to the alternator. Unless I've got this all fucked up and that'd be why the quiz was posted to begin with.  :evil:
« Reply #6 on: April 06, 2009, 11:08:32 PM »
im gunna half to check on that myself that shit stumped me
« Reply #7 on: April 06, 2009, 11:36:52 PM »
I have my battery in the back,  Big power wire comes through the firewall to a distibution block
1 wire to the starter 1 wire to fuse box
Does that help?
« Reply #8 on: April 07, 2009, 09:59:33 PM »
wish i was baller enough to have my battery relocated. but to much track B.S needing the kill switch and eveything else.
« Reply #9 on: April 07, 2009, 10:05:01 PM »
You seen mine!  You know its not baller or done the right way...  (NO CUT-OFF SWITCH)
When you gonna change that sig!!!  You know you got some love for the Almighty D in your heart.......
« Reply #10 on: April 07, 2009, 10:36:15 PM »
No takers???
7/16-20 UNF
Atleast 13 in every Civic 1992-1995, haven't check the other generations.
« Reply #11 on: April 08, 2009, 12:58:13 AM »
7/16-20 UNF
Where are those, and why hasn't anyone figured out my fuel pump plug yet?
« Reply #12 on: April 08, 2009, 01:58:56 AM »
fuel pump answer B :-\
that is true i love my d you need that switch for the track though there bitches like that.
« Reply #13 on: April 08, 2009, 03:16:51 AM »
7/16-20 UNF
answer my extra credit question and I might research yours.....if  you buy the beer.
bikewrench
« Reply #14 on: April 08, 2009, 06:16:25 PM »
seat belts
« Reply #15 on: April 08, 2009, 06:35:55 PM »
7/16-20 UNF
I'm not a honda person, but I seem to remember finding either 11mm fine thread or 13mm fine thread bolts in the bottom end of a friends prelude. Rod bolts IIRC, or perhaps main bearing bolts...
« Reply #16 on: April 08, 2009, 07:57:19 PM »
bikewrench is correct :yes:.  DOT...  usdm crash test standard bs...
Fuck a 5g.  Crxw/alogFTMFW...  Your plug "Just Don't Matter" if you have run proper 8/10 guage for your fuel pump wiring.
I think her name is Alopecia Areata Davis...
« Last Edit: April 08, 2009, 08:07:02 PM by Foowee »
