Pages: [1] 2 3   Go Down
Author Topic: Weirtech FTW  (Read 98279 times)
Weirtech FTW
« on: June 30, 2010, 01:48:01 PM »
He's going to start welding it all together on Monday.
Re: Weirtech FTW
« Reply #1 on: June 30, 2010, 01:59:21 PM »
WAT
Re: Weirtech FTW
« Reply #2 on: June 30, 2010, 02:01:45 PM »
WAT
maybe one of these days the motor will be together so i can actually use it  :'(
Re: Weirtech FTW
« Reply #3 on: June 30, 2010, 06:26:51 PM »
thats sexy
Re: Weirtech FTW
« Reply #4 on: June 30, 2010, 06:36:45 PM »
Looks pricey
My intake manifold setup for the h23a blue top for my crx is pretty simple. Top mount manifold. Cnc ported bottom half manifold+hand finished blending. 83-77mm throttle body. I may add a delrin plenum spacer but the manifold setup should easily outflow the head so I have no worries.
Re: Weirtech FTW
« Reply #5 on: June 30, 2010, 11:15:05 PM »
DFE designed? Whats the plenum volume and what wave are the runners tuned to? Pro3's?
Re: Weirtech FTW
« Reply #6 on: July 01, 2010, 01:37:58 AM »
designed by aaron.  He knows the full details of the build and tailored the manifold around it.  Yea, pro3's  I dont know the answers to those questions as I put everything in his hands.    There will be a dyno comparison between my stock EuroR and this manifold tho while the engine is on Don's engine dyno.
Here's the full run down on the motor:
H23 block bored to 90mm
h23 crank lightened balanced and oiling modified
Custom DFE spec CP pistons (total of ~14:1 compression) built around the Pro3's
Custom BME aluminum H22 rods
ARP main studs
Main oiling system enlarged (mains, bearings, pump)
CC Cylinder heads port work
Skunk2 Pro3 camshafts
Skunk2 Pro valvetrain
Skunk2 oversized valves (the newest design)
Skunk2 Pro cam gears
Gen1 RMF Narrow header (will be designing my own with hood exit)
Injector dynamics 725cc
Aeromotive FPR
Aeroquip fuel feed and return lines (*)
Weirtech custom AL intake manifold
PB Tuning 68mm throttle
custom length tuned megaphone intake
Trans/drivetrain:
comp twin disk
Mfactory LSD
Mfactory 5.15 FD
Syncrotech moly carbon syncros
Gator axles
ESP Traction Bar
Innovative motorsports mounts (*)
Exospeed STAR5 15x8 wheels with 4" backspacing (*)
24.5x8.5 slicks(*)
(*) = still need to buy
i dont have tooo much left.  Bout time cuz its been down since september collecting dust in the shop and im ready to drive this nigger into the ground
Re: Weirtech FTW
« Reply #7 on: July 01, 2010, 01:43:35 AM »
and im sorry, i know you guys dont really care for NA but.......
FUCK YOU.
SDRAWKCAB
  • D series BALLA!
  • Rhino
Re: Weirtech FTW
« Reply #8 on: July 01, 2010, 11:30:10 AM »
ARP main studs
Aeromotive FPR
Trans/drivetrain:
comp twin disk
Mfactory LSD
Mfactory 5.15 FD
Gator axles
ESP Traction Bar
24.5x8.5 slicks(*)
And I will get walked on by a stock d16a6 on 15 pounds
Re: Weirtech FTW
« Reply #9 on: July 01, 2010, 11:56:58 AM »
ARP main studs
Aeromotive FPR
Trans/drivetrain:
comp twin disk
Mfactory LSD
Mfactory 5.15 FD
Gator axles
ESP Traction Bar
24.5x8.5 slicks(*)
the day that happens, i will put it in a hatch.
Re: Weirtech FTW
« Reply #10 on: July 01, 2010, 12:32:36 PM »
I have a n/a build on the go to  :-[
but I also have 3 boosted ones  :P
Re: Weirtech FTW
« Reply #11 on: July 01, 2010, 12:54:40 PM »
You lie, you have a house build on the go, that is all.  :P
Re: Weirtech FTW
« Reply #12 on: July 01, 2010, 01:39:24 PM »
truth  :'(
Re: Weirtech FTW
« Reply #13 on: July 01, 2010, 02:10:28 PM »
i hope you dont rellay have bme s in the motor...... becuse they wont stay in the motor for long ::)
Re: Weirtech FTW
« Reply #14 on: July 01, 2010, 02:19:07 PM »
whatever happens happens.  I've got an oil temp gauge, oil pressure gauge and a nice crank case vent system.  I'm not reading into the bullshit you hear about AL rods when 99% of the people saying shit will happen are just listening to other people on the internet run there mouth.
I had the option of running carillo ProA's like every other nice NA build or stepping it up and running an AL rod for the same price of the carillos.  It was pretty clear to me.
Bill Miller told me as long as i dont beat on it outside the window of oil temp that he wants me to see when racing, i'll be fine.  I've got a great engine builder and i dont believe he would steer me in the wrong direction.
Re: Weirtech FTW
« Reply #15 on: July 01, 2010, 02:33:48 PM »
Aluminum rods work. They just have a fixed and definite life span. Makes them good for race motors, and lousy for street motors.
Re: Weirtech FTW
« Reply #16 on: July 01, 2010, 02:56:51 PM »
its not fixed at all from what bill told me.  They have to be treated correctly and given the right conditions/bearing clearances/oiling...etc.  He said if this was for a regular street car that would typically never be beat on, they could last for 100k miles.  Obviously thats not going to happen with this motor as its not truly a street car and im not raelly asking for it to last that long.
I have a daily driver but this car might get driven to work on fridays since that is when most of us drive our race cars to work.  its still registered, insured and tagged.  Trailered to the track where it will spend a majority of its lifetime.  We were also going to run CP low tension rings, but they suggested we not do that since im not running a vacuum pump setup.
Re: Weirtech FTW
« Reply #17 on: July 01, 2010, 03:25:56 PM »
Id like to see the vac setup kthx.
Re: Weirtech FTW
« Reply #18 on: July 01, 2010, 04:10:56 PM »
any reason your not going to run some kinsler's?
Re: Weirtech FTW
« Reply #19 on: July 01, 2010, 06:03:11 PM »
when its completed, i'll show you.
Re: Weirtech FTW
« Reply #20 on: July 01, 2010, 06:03:47 PM »
cuz they are close to 3000 for the setup i want (top feed)
Re: Weirtech FTW
« Reply #21 on: July 01, 2010, 06:55:41 PM »
i need opinions on anodizing colors since my girlfriend called me gay for wanting basic colors..... :(
so here are some that i liked:
Black IM, Polished/silver Weir Tag, Kawasaki green fuel rail
same as above but with purple rail (wiggins baller coupler purple)
First i told aaron to make the im silver with black tags and black fuel rail.  Apparently that is gay.
throw some serious ideas my way.  The car is metallic red, engine bay is black, block is black, VC will be black, coolant hoses are kawasaki green :)
Re: Weirtech FTW
« Reply #22 on: July 01, 2010, 07:02:30 PM »
Please do not anodize that manifold. It WILL look like shit.
Satin (raw) finish and black rail/accessories PLZKTHX
tell your boyfriend to shut the fuck up and call you by my last name next time she sux your cock, shell like it. ALOT....Her invigoration will cause you to like it too.  It wouldnt make you gay, It will just make her a slut.
Sluts are cool.
NO FUCKING ANODIZING OF AT LEAST THE IM  K?
narfdanarf
Re: Weirtech FTW
« Reply #23 on: July 02, 2010, 12:05:13 AM »
Definitely nothing wrong with the BME rods, that is what is going in my next motor when this one shits itself.  Just make sure they send you the big rod bolts.
I would love to build a n/a motor someday....good luck!
Re: Weirtech FTW
« Reply #24 on: July 02, 2010, 01:52:19 AM »
Sluts are cool.
opinion strongly noted sir thanks
Re: Weirtech FTW
« Reply #25 on: July 02, 2010, 01:52:43 AM »
yep they came with the big rod bolts.
narfdanarf
Re: Weirtech FTW
« Reply #26 on: July 02, 2010, 02:19:57 AM »
can you post a pic.
Re: Weirtech FTW
« Reply #27 on: July 02, 2010, 02:55:03 AM »
also some aluminum filler does not take anodizing
Re: Weirtech FTW
« Reply #28 on: July 02, 2010, 03:06:32 AM »
the last manifold aaron built i saw looked great, then he anodized it. i wanted to throw up.
Re: Weirtech FTW
« Reply #29 on: July 02, 2010, 05:49:15 AM »
I think that was the s2000?
Pages: [1] 2 3   Go Up
