Author Topic: hesitation issue  (Read 12363 times)
davidawg
hesitation issue
« on: July 01, 2010, 08:12:01 PM »
i have this bogging/hesitation issue that i can not figure out.  it does it from 0-7psi and 25%-90% throttle.  it shows low to mid nines on the afr gauge when it does this too.
did a boost leak test, nothing. ive tried leaning it out, nothing.  swapping to an old tune that i know works, nothing.  new thottle position sensor, nothing.  swapped o2 sensor, nothing.  swapped coil over plugs, nothing.  my spark plug gap is at 26-28.
you can hear the problem in this video from 0:35- 0:40
turbo zx2 vs modified evo 9 mr 1
im out of ideas...
a lil something to help ya think, lol
« Last Edit: July 01, 2010, 08:52:44 PM by davidawg »
i drive in the mountains
Re: hesitation issue
« Reply #1 on: July 01, 2010, 09:03:45 PM »
welcome to my life last year
davidawg
« Reply #2 on: July 01, 2010, 09:15:55 PM »
what was the answer to your problem?
« Reply #3 on: July 01, 2010, 11:10:43 PM »
Tom Sewell
davidawg
« Reply #4 on: July 02, 2010, 03:22:33 AM »
wtf??????
i read through 16 pages and your problem magically goes away?  fuck my life!
ifly87
« Reply #5 on: July 02, 2010, 03:49:48 AM »
is the boost fluctuating at all? like compressor surge?
Lol...Fags
davidawg
« Reply #6 on: July 02, 2010, 03:51:53 AM »
boost jumps up(like two step i guess)
2slow
« Reply #7 on: July 02, 2010, 06:24:39 AM »
You should try throwing more parts at it :noel:
« Reply #8 on: July 02, 2010, 08:45:40 AM »
your motor doesnt like 9-1 afr's
davidawg
« Reply #9 on: July 26, 2010, 03:00:49 AM »
these are the parts ive thrown at the car since...
cranksahft position sensor
camshaft position senosr
maf
head gasket
ecu/pcm/ecm/computer(whatever you like to call it)
i tried running it n/a and it missed up top too
what else is left?
« Reply #10 on: July 26, 2010, 06:33:41 AM »
It's probably having problems lighting off low to mid 9 AFR's.
Lean it out in that area.
davidawg
« Reply #11 on: July 26, 2010, 09:49:04 AM »
ive already tried that and swapping to an old tune that worked without any problems
« Reply #12 on: July 26, 2010, 12:52:24 PM »
What are you using to tune it?
« Reply #13 on: July 26, 2010, 04:39:49 PM »
maf
head gasket
what else is left?
there's your problem
« Reply #14 on: July 26, 2010, 05:06:37 PM »
You know nothing about Fords.
« Reply #15 on: July 26, 2010, 07:11:10 PM »
lol
davidawg
« Reply #16 on: July 26, 2010, 08:44:24 PM »
im using delta force's special forces tuning.  we zx2 people only have sct and delta force to choose from as a simple tuning solution.  i chose delta forces cause it allows you to tune two vehicles for the price of one and i own two zx2's.
« Reply #17 on: July 26, 2010, 09:20:04 PM »
I'm not familiar with their product, I've been porting them into Binary Editor and then flashing unlimited vehicles through a Drew Tech Mongoose SCI cable
Does it allow you to deal in binaries?  Or is the tunefile unencrypted so you can yank the .bin out of it like SCT's .mtf files?  Also, got datalogs?  One general log and 1-2 really short ones that replicate the problem should do.
