Author Topic: my problem with crome...  (Read 13870 times)
walter
« on: July 07, 2010, 02:43:18 PM »
hi guys, i bought crome license recently , i have to say i tried ago some weeks back with 1.5.0 cracked but i had problems with nokia datalogging cable since it didnt connects, decided to buy a new xtreme hulog and samething happens, romulator always connected with the hacked version, then bought crome licence like i said before, was thinking maybe the problem was the cracked shit verison so i bought a original licence one, then i tried today and i had problems connecting hulog fist time ,  played with coms and got it connected already, so hulog connects with ecu, then i tried romulator and never connects, as comments  happens a very weird thing, when i plug romulator usb and hulog usb to  my little laptop, hulog doesnt connects, when i unplug romulator usb, hulog connects with ecu, what's happen? im getting crazy with this already, even ill pay some money who can help me for to fix this please, well after to notice that weird thing about plug both cables, i only tried only with romulator cable, tried almost every com and not connects, not sure what do i can do , i will not buy a ostrich since romulator was working very good with turboedit.
i dont know if problem will be my laptop, it's new, using XP, it's EEE PC ASUS
please buddies, help me, i dont know what do i can do more...
i hope your helps please.
« Last Edit: July 07, 2010, 03:08:13 PM by walter »
Re: my problem with crome...
« Reply #1 on: July 07, 2010, 02:55:13 PM »
Damn, your English is horrible :P
Are you able to datalog when hulog is connected? Are you sure the connector is not plugged backward  in the ECU?
walter
« Reply #2 on: July 07, 2010, 03:00:23 PM »
sorry for my english, thought was improving.
i didnt try if it works, i check for connection to ecu only. my problem is with romulator, datalooging connects correctly.
« Reply #3 on: July 07, 2010, 03:07:26 PM »
I ask cause if I remember well, I had problem with connector connected backward and USB port fucking up.
walter
« Reply #4 on: July 07, 2010, 03:10:31 PM »
fixed a bit my english i hope be better, hulog connects good already after to play with com's but right now i can't connect romulator, played with com's and not luck, im not sure if it's has to do with that weird problem when i plug both usbs nothing connects and when i plug only hulog usb it connects correctly..
walter
« Reply #5 on: July 07, 2010, 05:15:30 PM »
nobody? i can give even some money for helping me guys!
« Reply #6 on: July 07, 2010, 06:37:57 PM »
tits?
« Reply #7 on: July 07, 2010, 07:47:49 PM »
SGo to FTDI's site and download their USB driver cleaner.  There should be how-to's about this on Moates.net.
Sometimes this COM port shit sucks.  Out of the blue my Burn1's stopped working out of my lefthand USB port.  They generate a COM port correctly, but nothing (Flash&Burn, Tunerpro, Crome, eCtune) will recognize it.  Plug it into either of the righthand USB ports and it's fine.
You may need to reinstall XP to fix this, but do that as a last resort.
walter
« Reply #8 on: July 07, 2010, 08:47:40 PM »
reinstall xp? wow, how its possible if this is a brand new laptop? thanks for replys, anywya ill get a ostrich, and aill try tomorow and ill let you know...
thanks!!
« Reply #9 on: July 07, 2010, 11:20:30 PM »
Windows is weird.
« Reply #10 on: July 08, 2010, 12:33:27 AM »
I had a similar issues with my new laptop. I used the FTDI cleaner then reinstalled the drivers.
Following the post tutorial from Moates I figured out that my com port for my Burn2 was wrong I just changed the COM address.  ;D
And it has work for me now for 3 mo. now. ;D
« Reply #11 on: July 08, 2010, 12:33:58 AM »
Walter Ive warned you about this already.
http://www.realhomemadeturbo.com/forum/index.php?topic=6203.0
The Romulator is no longer supported by Crome.
It hasn't been since version 1.5 There is nothing you can do to make the romulator work.
Sell the romulator and buy proper moates gear. And oh yeah turbo a fucking car already it's been five years.
walter
« Reply #12 on: July 08, 2010, 06:46:08 PM »
hi, yep, you are right, today i tried with 1.5.0 version , changed usb port , installed drivers since i changed usb port (not com) and both connects, just i datalog slow and not works as i'd like it does, ill get a ostrich soon.  :-\
« Reply #13 on: July 08, 2010, 07:02:27 PM »
why did you "buy" crome?
you know for a few more dollars you could have a management system that hasnt fallen off the face of the earth...
« Reply #14 on: July 08, 2010, 07:24:15 PM »
Because ectune sucks
walter
« Reply #15 on: July 08, 2010, 07:28:51 PM »
for works with ostrich, ive read and it's a shit for me, you need Demon, it's $$$, and you only will tune your car, besides, im not a PRO Tuner (yet?), ive see 10000 options that idk what means , so crome will be good for me so far, forced updates sucks..
« Reply #16 on: July 08, 2010, 07:46:38 PM »
Ectune works with Ostrish, that's what I use.
walter
« Reply #17 on: July 08, 2010, 07:49:14 PM »
yes, it does.
« Reply #18 on: July 10, 2010, 02:01:24 AM »
good job walter. I didn't think about reverting to an older version. Now go force induct your car
walter
« Reply #19 on: July 10, 2010, 07:29:34 AM »
ill do, datalogging works a bit slow, ill make a video, ordering ostrich very soon.
