Author Topic: Windows Recovery No cd  (Read 4971 times)
Avistar23
« on: July 21, 2010, 05:39:30 PM »
Im reallllyy frustarted right now
windows is saying system conifg file is missing or corrupt, need to run recovery
i lost my xp cd i have here
i left my recovery cd in school in canada
and everything online is saying i need the cd
how do i get into recovery
computer is lenovo g550 and the recovery button on it wont work at all....
F250 4x4 7.3 Diesel
International 4900 DT 466E
Re: Windows Recovery No cd
« Reply #1 on: July 21, 2010, 05:49:18 PM »
lol... did you delete system32 in order to speed up web browsing?
tell us how you got here, might even be a hardware issue
Avistar23
« Reply #2 on: July 21, 2010, 06:15:44 PM »
Came home from work, computer was off, thought that was strage...try to turn on and this is what ive got
also giving me blue screen when i try some recovery cd, blue screen telling me to check hard drive.
F250 4x4 7.3 Diesel
SgtB
« Reply #3 on: July 21, 2010, 08:53:23 PM »
Automatic updates enabled? May have fucked you. Try using a friends computer to burn one of the 300x10^135 copies of xp on bit-torrent. The CD doesn't have any special shit on it, so any copy will work as long as it's the same edition.
Avistar23
« Reply #4 on: July 21, 2010, 09:08:07 PM »
Ive tried to do a fresh install, and its blue screening, i tried putting in another hardrive and booting from cd, it gets to "starting windows" in the install and then blue screens again....
im getting very confused...  i found some emergency recovery disk online...
F250 4x4 7.3 Diesel
« Reply #5 on: July 21, 2010, 09:12:34 PM »
I've had computers that were a shitfight to do an install on.  Keep trying, once it takes you should be fine.
« Reply #6 on: July 21, 2010, 09:26:49 PM »
low level format that bitch, then try a fresh install.
You might have some boot sector BS going on.
SgtB
« Reply #7 on: July 21, 2010, 10:24:31 PM »
If it's a boot sector you can always use fixboot with the /mbr switch in the recovery console.You could also have a dead mobo or videocard. I have an old as dirt amd that I was going to trash. Found a bad capacitor on the videocard and swapped the card for a new one. Runs like a champ now.
« Reply #8 on: July 21, 2010, 11:55:08 PM »
as I expected, this is for sure a hardware issue. the "missing or corrupt file" shit has been coming around since 1996 to tell you you oc'ed too much, too much heat, not enough volts, too much bus ^, or your hdd ate feces
Avistar23
« Reply #9 on: July 27, 2010, 10:30:23 PM »
So it had a bunch of bad sectors that chkdisk just found
took windows 7 pro
it works
im super happy
lost all my data, but the bitch is back on the road!
however need to change the brake fluid in my evo or else im going to hit a wall
and the map sensor took a shit in my moms Pajero Jr. and cant find one anywhere besides the uk for 150 pounds
thats all for now folks!
F250 4x4 7.3 Diesel
