Author Topic: ecu work stand  (Read 17623 times)
ecu work stand
« on: August 01, 2010, 04:48:58 PM »
just curious if anyone else has done this. i have never seen anyone talk about it, but one night of chipping i decided that i needed a stand so i built this out of some 1/2" square tubing i had laying around and stuck some rubber feet on the bottom. i wish i had done it a long time ago. i cant believe how much faster and easier chipping goes now.
i also dont give 2 shits what anyone thinks of the blue paint. i had some left over in the gun at work and did this at the same time
michigan_soler
Re: ecu work stand
« Reply #1 on: August 01, 2010, 05:33:30 PM »
I like to work over top on an almost flat surface. But I like the idea
Re: ecu work stand
« Reply #2 on: August 01, 2010, 06:30:56 PM »
I use the spring loaded solder sucker so I have to be able to get to both sides at the same time. I used to solder everything in with it laying flat on the table, but once I got used to this I like it better.
DasPoop
Re: ecu work stand
« Reply #3 on: August 01, 2010, 07:05:31 PM »
thats pretty sweet. I would build one that rather than flat i would lay it vertical and be albo to lock it into say flat 45 90 45 and flat again. i bet that would save time over holding it between your legs haha
Re: ecu work stand
« Reply #4 on: August 01, 2010, 07:46:53 PM »
I use a hobby vice.
michigan_soler
Re: ecu work stand
« Reply #5 on: August 01, 2010, 07:47:31 PM »
I rock a radio shack bulb sucker.  I just prop it up about 2-3 inches on what evers around.
I would like a 20*-ish angle...  ill have to see what I have laying around...
DasPoop
Re: ecu work stand
« Reply #6 on: August 01, 2010, 07:52:19 PM »
still rockin solderwick. once you get the hang of it you can see and smell when its all sucked up.
SgtB
Re: ecu work stand
« Reply #7 on: August 01, 2010, 10:09:06 PM »
Looks good. I use a dremel vise for most of my board work.
toyolla86
Re: ecu work stand
« Reply #8 on: August 05, 2010, 12:17:28 PM »
the best are the ones that swivel in any direction.
i used one to build my megasquirt and it was a lifesaver.
twin50 son. get some
and stop acting like a muslim
Re: ecu work stand
« Reply #9 on: August 05, 2010, 12:21:23 PM »
I really haven't had a need to do anything but spin it on the base. I also only work on Honda ecu's. Hopefully I can assemble an MS unit for a turbo cafe racer in the near future
toyolla86
Re: ecu work stand
« Reply #10 on: August 05, 2010, 12:27:56 PM »
oh good. well then that works out just fine.
nice little stand btw
Re: ecu work stand
« Reply #11 on: August 05, 2010, 06:36:01 PM »
Does the stand bolt to the table or does it just slide around?
Re: ecu work stand
« Reply #12 on: August 05, 2010, 10:16:20 PM »
it has rubber feet to keep it from sliding, but nothing securing it to the table. it works surprisingly well. so far i havent wished i had done anything different
Re: ecu work stand
« Reply #13 on: August 06, 2010, 12:42:27 AM »
I think I would be annoyed by having to bolt it into that framework.  Tossing one around in my lap has worked great so far for me.
Hey, maybe you can make a couple and sell them, use the money to buy a desoldering iron?  That's going to be my next purchase, they rock.
Re: ecu work stand
« Reply #14 on: August 06, 2010, 07:14:26 AM »
Not a bad idea. I would really love a desoldering iron. The $5 radio shack solder sucker has never done me wrong but it does leave a bit of a mess to clean up. I do my best to make my chipping look factory.
Not sure where there would be a market for that though since everyone here can weld. Maybe I can just chip enough ecu's to buy one. That business has picked up around my area quite a bit.
Re: ecu work stand
« Reply #15 on: August 06, 2010, 12:25:19 PM »
Good work!   :yes:
Re: ecu work stand
« Reply #16 on: August 06, 2010, 07:09:12 PM »
Make a YouTube video of the stand in action, and throw it up on eBay.  Rinse and repeat.
Re: ecu work stand
« Reply #17 on: August 06, 2010, 10:49:32 PM »
Good thinking sir. If you didn't have so many internetz already, I would hook you up with a few
Re: ecu work stand
« Reply #18 on: August 06, 2010, 11:16:32 PM »
Thank you, but I agree that your internets are best spent elsewhere.
Re: ecu work stand
« Reply #19 on: August 07, 2010, 09:04:41 AM »
Sell 5 to Chris Harris!
Re: ecu work stand
« Reply #20 on: August 07, 2010, 10:17:22 AM »
Chris might not buy them outright, but he'd be happy to do a consignment deal for the first few so you can both see how they sell.
Re: ecu work stand
« Reply #21 on: August 07, 2010, 05:31:56 PM »
With my luck he would sell them to some Canadian for $20k who would then patent it and proceed to ruin it.
