Author Topic: s3oo dyno interference?  (Read 11154 times)
mrgreengenes
« on: August 05, 2010, 10:46:41 AM »
anyone unfortunate enough to have had to tune an s3oo unit on an eddy brake dyno have the car act completely retarded?  Say, down 50% power, and dropping out after 6000rpm?
stock ignition, 7's resistor plugs, typeR rods/pistons, 57trim, tuning non vtec only so far, 11psi at most.
regards
phil
Re: s3oo dyno interference?
« Reply #1 on: August 05, 2010, 11:12:29 AM »
So the car operates differently on the street?  y/n?  You've had it back off the dyno to verify the problem only exist on the dyno?
S300 is a huge antenna, I'm not surprised an eddy brake wreaks havok with it.  Although, there might be a problem with the eddy brake that is causing extra interference since S300 + eddy brake dynos work fine for other people.
mrgreengenes
« Reply #2 on: August 05, 2010, 10:30:47 PM »
no road testing yet.
we did an experiment, where we unplugged the dyno an operated it as inertia only.  We netted a repeatable 210hp.
Then we tried with the dyno plugged in, with no eddy load, same result.
We put a 1% DC(minimum) load with the eddy, and lost 18-20hp, and the torque curve looked like it had an ignition fallout after 6500rpm.
FYI:  we were tuning the car up to then with a 30% load. It was falling off HUGE after 6000rpm, bucking like a chick after you tell her she's fat whilst nailing her from behind...
The eddy brake is approx. 3 feet from the ecu
« Reply #3 on: August 06, 2010, 12:40:54 AM »
Which dyno?
mrgreengenes
« Reply #4 on: August 06, 2010, 12:43:25 AM »
dynocom
« Reply #5 on: August 06, 2010, 12:48:33 AM »
Ah, you're the guy with the Pod units.
I get the feeling there really is no load in inertial mode, which means there is an outside chance it's a common ignition misfire.  THe engine doesn't misfire until under a certain amount of load, and you aren't reaching it.  1% duty isn't indicative of a whole lot, inductive reactance could have the load a 1% be relatively significant... although you would ASSume the loading control to be a smooth and uniformly incremental affair so that 1% doesn't induce any significant load.
Look, you suspect the dyno.  Only way to test is put the wheels back on and roll the car down the road.  I'm pretty curious, too.
SgtB
« Reply #6 on: August 06, 2010, 11:17:24 PM »
How's the ground connection on the dyno? If the grounds bad  a leaky coil will transmit instead of tripping out through the ground lead.
« Reply #7 on: August 09, 2010, 12:55:19 AM »
If JD is right, give it a shot in inertia mode while holding the brakes down a bit. Just don't fry them.
Otherwise wrap the ecu in tin foil, preferably copper anti-EMI tape, then wire that to the chassis and to the building's ground (plumbing/etc).
mrgreengenes
« Reply #8 on: August 11, 2010, 04:28:45 PM »
great idea with the foil.  set oven to 400f and bake for 20 minutes.  The car itself is fucking up, tried on the street, and datalogged a couple of runs.  1st one logged properly, with semi fucked readings after 5000rpm and the TPS dropping signal before i let off.  The other times, logging just froze up.
super sweet.  Need to check grounds.
« Reply #9 on: August 11, 2010, 04:39:15 PM »
So it takes you guys two weeks to tune cars?
mrgreengenes
« Reply #10 on: August 13, 2010, 12:17:46 AM »
Yeah, and every one we do we lose money on.  How do we stay in business, you may ask?  VOLUME!  hahaha but srsly no, we've been juggling a bunch of other shit work and put this on the back burner.  All done now, took out the s3OO unit and tuned it on crome, made 404hp at 15-16psi.
« Reply #11 on: August 13, 2010, 04:18:51 AM »
Removing S300 is always my first option.
« Reply #12 on: August 13, 2010, 09:11:04 AM »
Sound like another argument against Honda.  :?: ;D :yes:
