Author Topic: turbo oil drain causing smoke?  (Read 23376 times)
gdout90accord
« on: August 13, 2010, 01:32:34 AM »
well my brand new turbo is smoking, will it be the oil drain? heres a pic
http://img.photobucket.com/albums/v417/GDOUT/6da74d45.jpg
i have a adjustable oil restrictor on the feed line which is 3/4 closed and it still smokes at high RPM. With the restrictor half way closed it smoke on idle. lmk what u think. thanks
« Last Edit: August 13, 2010, 06:03:10 PM by gdout90accord »
SDRAWKCAB
  • D series BALLA!
  • Rhino
Re: turbo oil drain causing smoke?
« Reply #1 on: August 13, 2010, 01:35:03 AM »
Drain looks fine.
Whats your oil pressure at?
Are you using a fram oil filter?
Deleted User
« Reply #2 on: August 13, 2010, 01:37:13 AM »
Also what turbo are you running and how much psi, if its ebay and u r running over 15psi i wouldnt be surprised that it is smoking. Also im not a fan of the adjustable restrictors just my 2 cents. Also is your turbo sucking the air in front of that alternator or is it below it and the picture is deceptive?
Deleted User
« Reply #3 on: August 13, 2010, 01:38:23 AM »
Drain looks fine.
Im using the slutty Fram bitch, whats wrong with them?
gdout90accord
« Reply #4 on: August 13, 2010, 01:40:13 AM »
turbo is a real garrett t3t4 60 trim and using s2000 oil filter. only running 10psi and turbo is below that alternator.
SDRAWKCAB
  • D series BALLA!
  • Rhino
« Reply #5 on: August 13, 2010, 01:50:34 AM »
Drain looks fine.
They flow like complete shit and cause ultra high oil pressure.
http://people.msoe.edu/~yoderw/oilfilterstudy/oilfilterstudy.html#warning
« Last Edit: August 13, 2010, 01:53:22 AM by SDRAWKCAB »
« Reply #6 on: August 13, 2010, 09:54:30 AM »
Drain looks fine.
Interesting read that confirmed what I always knew about Fram's crap. BTW sidenote the KNN filter is just Mobil 1 filter with a 1" nut on the end for easy removal and provisions for safety wire.  ;D
« Reply #7 on: August 13, 2010, 12:33:09 PM »
How do you know it's the turbo? Probably rings...
2slow
« Reply #8 on: August 13, 2010, 12:39:04 PM »
Whats your pcv setup
« Reply #9 on: August 13, 2010, 12:44:10 PM »
What size feed line?
And we're going to need a better picture than that. The drain line itself may be ok, but the angle of the turbo might be off.
SDRAWKCAB
  • D series BALLA!
  • Rhino
« Reply #10 on: August 13, 2010, 02:54:41 PM »
« Reply #11 on: August 13, 2010, 02:56:18 PM »
In other words are you using a catch can or just stock pcv system?
gdout90accord
« Reply #12 on: August 13, 2010, 05:39:50 PM »
feed line is 3an with that adjustable restrictor and as for the pcv system, both pcv and vc port to catch can inlet and just a breather filter on the outlet of the catch can. the angle of the turbo is not straight down but kinda clocked a little bit.
« Reply #13 on: August 13, 2010, 05:48:28 PM »
Where is your intro post?
gdout90accord
« Reply #14 on: August 13, 2010, 05:49:02 PM »
2slow
« Reply #15 on: August 14, 2010, 02:15:29 AM »
The way you decribed the pcv system it sounds like you still have your pcv valve there. If so you need to get rid of that shit
gdout90accord
« Reply #16 on: August 14, 2010, 11:43:59 AM »
Yea I still have da stock pcv valve connected to the catch can, I guess ill take it out and see if it helps.
SDRAWKCAB
  • D series BALLA!
  • Rhino
« Reply #17 on: August 14, 2010, 11:57:00 AM »
DING DING DING!
2slow
« Reply #18 on: August 14, 2010, 04:06:51 PM »
Well theres your problem now punch yourself in the nuts six times
gdout90accord
« Reply #19 on: August 14, 2010, 04:11:14 PM »
well ive had the same set up on the last turbo/manifold set up and never smoked like it is right now
2slow
« Reply #20 on: August 14, 2010, 05:14:21 PM »
Ok well then you need to do a few different things. First  get rid of the adjustable oil restrictor, then fix pcv setup, after that punch yourself in the nuts, once done with that you need to post porn before anyone else will help you any more
