Pages: 1 [2] 3 4   Go Down
Author Topic: digikey part number list for obd1 vtec chipping kits  (Read 68016 times)
walter
Re: digikey part number list for obd1 vtec chipping kits
« Reply #30 on: May 05, 2009, 03:31:37 PM »
great! and Futurlec send stuff to europe. just they havent 27SF512 and Aries S4,i was wondering if this zif should works too ..
28 pin of course. and if 27SF512 chips will fits on it.
Platinum8317
« Reply #31 on: May 05, 2009, 03:46:49 PM »
Def. looks like they should fit. yeah the 27sf512 are discontinued. No place has them that I could find except ebay, xeno and moates.
« Reply #32 on: May 05, 2009, 05:14:53 PM »
Fuck a ZIF, get machine pin sockets and reap their eternal reliability.  Best of all, you can buy them from a company called ASSMANN.   :)
http://www.usa-assmann.com/Specs/ARxx-HxL-TT-R.pdf
Also, PWM is the same transistor as used by the IACV circuit, 220 and 330 ohm 1/2 watt resistors, and a 1N4002 diode (have used lesser rated 4001s with no problems).
walter
« Reply #33 on: May 06, 2009, 09:54:53 AM »
i assume not use ZIF if you runs with ostrich or something like that, but if you runs without one and need remove chip all the time, using zif is easiest..
« Reply #34 on: May 06, 2009, 10:49:28 AM »
Not when the ZIF falls apart.  They are pretty fragile.
« Reply #35 on: May 06, 2009, 11:56:50 AM »
ass is the past tense of essen
Das ist gut LOL
Platinum8317
« Reply #36 on: May 06, 2009, 10:49:42 PM »
JD- Can I use 1n4004 for the diode? also I'm not sure which circuit the iacv is. Can you point me to what is the transistor type and are there suppose to be two transistors? the pwm kits sold show two totally different transistors. Thanks.
Dweezil
    • Michigan Civics
« Reply #37 on: May 06, 2009, 11:41:33 PM »
D14: 512-1n4002 (1N4002DICT-ND)
R70: 220 ohm (220ebk-nd)
R71: 330 ohm (330ebk-nd)
Q20: 526-nte2368 (2SB1030ARACT-ND)
Q29: 511-mje3055t (497-2573-5-ND)
http://forum.pgmfi.org/viewtopic.php?f=2&t=17649&p=111282&hilit=q20#p111282
« Reply #38 on: May 07, 2009, 02:33:53 AM »
One is one of the small transistors everything uses, in this case to switch the big transistor on and off.
You have all the part numbers there, so...?
Platinum8317
« Reply #39 on: May 08, 2009, 05:01:24 PM »
OK great thanks. Now as far as the 1n4002. I know the differences between the 1n4002 and the 1n4004 is that the 1n4004 has a much higher reverse voltage rms, I just want to know if i can use the 1n4004 instead of the 1n4002. Only reason I ask is cause I already have a bunch of 1n4004 for chipping kits and don't want to have to buy a different one if i have to. Thanks.
« Reply #40 on: May 10, 2009, 11:30:44 AM »
1N4001-1N4004 are interchangeable.  It's just a silicon diode, dude.  Passes voltage one way with a 0.3v drop, and refuses it the other direction.
Platinum8317
« Reply #41 on: May 11, 2009, 09:10:37 AM »
Thats exactly what I thought. Just wanted to double check. Thanks so much for all your help.
Platinum8317
« Reply #42 on: May 12, 2009, 10:50:43 AM »
Thought people might find this usefull, 27sf512 chips.
http://www.progshop.com/shop/chips/flash-eproms.html
« Reply #43 on: May 12, 2009, 10:52:14 AM »
bookmarked that.
walter
walter
« Reply #45 on: May 13, 2009, 03:57:15 PM »
what about parts for Hondata S300 Chipping Kit?
walter
« Reply #46 on: May 13, 2009, 04:04:32 PM »
BTW, i as looking for 27SF512 chips and i fount in Futurlec have this one:
http://www.futurlec.com/Memory/27512-200pr.shtml
not sure if they are the same as 27SF512. ???
Platinum8317
« Reply #47 on: May 14, 2009, 08:27:46 AM »
I'm not sure what is included in the s300 chipping kit. I was under the impression it was a normally chipped ecu they used. I'm comparing datasheets between the chip you found at futurlec and the 27sf512 that I  know works. But with a quick look i don't think they are the same.
« Reply #48 on: May 14, 2009, 12:43:04 PM »
i have a big supply of chips if you guys need to buy some....
Platinum8317
« Reply #49 on: May 14, 2009, 01:03:27 PM »
Thanks. I'm good with the amount i have now. I was just looking to see if people need them in the future and don't have to go through xeno and moates.
« Reply #50 on: May 14, 2009, 01:04:32 PM »
How much?
« Reply #51 on: May 14, 2009, 01:27:47 PM »
200 nanosecond memory = solid CEL.  The factory chipped Honduhs ran 170 ns memory, but I've had issues with 150 ns stuff.  You NEED 120 ns or better, and keep in mind that the last zero isn't always included in the part number so -20 is a 200 ns memory.
I believe 90 or 70 ns is the fastest these chips come in, and 250 the slowest (mostly old school 27C256 window chips), so don't thin a -25 is a screamer.  :P
« Reply #52 on: May 14, 2009, 01:50:52 PM »
i have a shit load but dude up here rapes me on them for $3 each and he has them at his house.
maybe if we go on a big ass group buy he will hook us up better.
let me know guys if youre interested.  lets do this shit. pm me if you know how many you need.
Jay
« Reply #53 on: May 14, 2009, 02:17:17 PM »
Need exact chip model, 300 pieces unless BRMS orders before i sync up with them.
« Reply #54 on: May 14, 2009, 02:36:21 PM »
they are 27sf512's...
« Reply #55 on: May 14, 2009, 03:54:43 PM »
different socket hondata shows the differences on their website
« Reply #56 on: May 14, 2009, 03:57:49 PM »
http://hondata.com/help/smanager/index.html
I just found 50 more 27sf512 ;D damn i ordered a lot couple years back
« Reply #57 on: May 14, 2009, 09:18:54 PM »
aight.  spoke to the dude.  2.50 each if we get 50 or more.
let me know guys.  he has 88 left
« Reply #58 on: May 14, 2009, 10:12:37 PM »
So the 27sf512 is no longer in production? Guess the maotes burner is going to be a thing of the past then
« Reply #59 on: May 14, 2009, 10:27:33 PM »
my supplier gets them straight from china...
Pages: 1 [2] 3 4   Go Up
