Author Topic: Build your own sandblaster cabinet!  (Read 41420 times)
stealthiskey
« on: April 08, 2009, 11:32:08 PM »
There's a few cheaper ways of doing this, but if you have the motivation a blaster cabinet can be a great thing to have.  I decided to build rather than buy so I could add a few things, and make sure it would be large enough to suit my needs.  I just use a $15 husky siphon feed gun.
Here's a shot of the whole thing.  Important points:
1.  Trough like base to collect the media.
2.  Slanted roof to make viewing easier.
3.  Cut off sweat shirt sleeves stapled to the arm holes to keep keep media inside.
4.  The windows get dusty, but don't really scratch.  Glass is easier to wipe than plexi.
Added an attached water/oil separator.  Wet air will clog the gun, and this also provides an easy point to connect your air hose on the outside of the cabinet.
This is a dirt bike air filter boot I happened to have.  Conveniently it perfectly fits my shopvac.  Hooking a shopvac to the cabinet during operation keeps dust from blowing and allows dust to settle faster when you are ready to open it up.  If you're worried about your shop vac motor you can add some water to the bottom of the vac to help keep dust down.  Mine has been fine, although the vac filter does need periodic cleaning.
Inside shot showing the dirt bike air filter.  It's just a mesh screen, but it seems fine enough to block the media.  As the media breaks down it turns to a finer dust and passes through the mesh.  Also take a look at the edge where the door opens.  I added a line of foam weather stripping all around to form a better seal when the door closes.
Here's the inside.  Made a grate out of rebar and screening to set parts on.  Also has a length of air hose permanently installed for easy setup.  Also included a flourescent light inside the cabinet to increase visibility when the windows get dusty.
Before:
After:
Re: Build your own sandblaster cabinet!
« Reply #1 on: April 08, 2009, 11:34:56 PM »
nice
« Reply #2 on: April 09, 2009, 12:17:32 AM »
badass
1slow91hf
« Reply #3 on: April 09, 2009, 12:19:17 AM »
might have to build me one of those for when i start cleaning up all my parts so i dont waste any media
thats the dimentions of your cabinet?
« Reply #4 on: April 09, 2009, 09:58:19 AM »
very nice.  I made one with plexi windows and just like somebody said..i cant see SHIT now.
« Reply #5 on: April 09, 2009, 10:21:05 AM »
badass.. i always thought these would be easy to make. hell it's just a box with an air compressor and gloves :)
props!
monty007
« Reply #6 on: April 09, 2009, 01:40:49 PM »
awesome job!!
g_shok
  • SuperSport
« Reply #7 on: April 09, 2009, 03:12:50 PM »
now put a cat in there and blast it
seajay2525
« Reply #8 on: April 09, 2009, 03:25:18 PM »
Sweet setup. This almost motivates me to start mine.
If there is a solution, why worry? If there isn'#39#39t a solution, why worry?
Logan76
« Reply #9 on: April 09, 2009, 03:38:02 PM »
What pressure are you running and what media? I know if you shoot glassoxide at anything above 70psi or so it seems to turn to a useless dust much faster, a pressure regulator is a good thing to have on blast cabinets.
Emperor
« Reply #10 on: April 10, 2009, 06:44:43 AM »
you could add a wiper inside to clear the window
thats how we do with our flavour mill ;D
but one thing scare me
did you ever read about ,,Dust explosion,, ?
NO?
Really?
just let you know
shitload of Dust + Electrical power = BOOM BOOM FAIL   :?:
http://en.wikipedia.org/wiki/Dust_explosion
think about your light inside
I saw two brewerys that blown up cause this shit O0 YEAHHHHHHH
RHMT Boost everything
-Cars
-Bikes
stealthiskey
« Reply #11 on: April 10, 2009, 09:10:14 AM »
My air compressor can maintain ~ 60-70 psi with continuous use, and has a regulator on it.  Higher pressures degrade the media faster, but also clean faster and leave a different surface finish.
yea dust explosion is a threat with some stuff, but this is sand, it doesn't really burn, ever.
did you mean like a meow meow?
« Reply #12 on: April 10, 2009, 10:05:05 AM »
the right mixture of combustable Dust + ignition source = BOOM BOOM FAIL   :?:
fixed for accuracy
also, someone needs to do a diy parts washer bin
Logan76
« Reply #13 on: April 10, 2009, 10:25:18 AM »
at my work we do some media blasting, and guys always want to run the glass bead at 100psi because theyre in a hurry, but it turns it to useless dust so damn quickly.
Whitey
« Reply #14 on: April 10, 2009, 12:19:41 PM »
fixed for accuracy
Lol, good thing sandblasting doesn't cause a shitload of static electricity.   :?:  My cabinet at work wasn't grounded properly and it arcs like a motherfucker
« Reply #15 on: April 10, 2009, 12:38:52 PM »
also a good thing that ROCK is not flamible, otherwise beaches and deserts would be on fire all the time
« Reply #16 on: April 10, 2009, 01:31:39 PM »
If you're blasting say, oh I dunno, a metal part, then there is some level of metal dust in the cabinet. Carry on.
« Reply #17 on: April 10, 2009, 03:52:50 PM »
coal isn't a rock?
« Reply #18 on: April 11, 2009, 01:31:18 AM »
coal isn't a rock?
no its hydrocarbons
and as for metal dust burning, steel-no, aluminum-no, titanium-no, sodium-yes, magnesium-yes.
flour mills and shit exploding is because its a hydrocarbon, sugar will burn. metal will readily oxidize if its super hot in a oxygen atmosphere (like a cutting torch nozzel)
as far as glass-no, silicon dioxide(sand)-no
« Last Edit: April 11, 2009, 01:35:01 AM by t_cel_t »
stealthiskey
« Reply #19 on: April 11, 2009, 11:10:12 AM »
That's interesting about static electricity.  Wood is an electrical insulator, so it can build up with static on the surface, but it will never shock you as  it does not conduct.  I guess metal cabinets have to worry about that.
« Reply #20 on: April 11, 2009, 12:51:23 PM »
coal isn't a rock?
no its hydrocarbons
I've personally seen aluminum dust burn. Anything will burn if it's hot enough. That's the problem. And a spark is really high temp, hence if the conditions are right, you get an explosion.
Whitey
« Reply #21 on: April 11, 2009, 12:57:07 PM »
Lol do you know how many manufacturing facilities are no more becuase of aluminum dust?  Aluminum dust (along with many others) is like a bomb.
Don't spread misinformation that could kill people
Emperor
« Reply #22 on: April 11, 2009, 02:01:36 PM »
yeahhhh ;D
dust explosions and you
an awesome adventure
[/size]
-Cars
-Bikes
« Reply #23 on: April 11, 2009, 02:18:34 PM »
coal isn't a rock?
no its hydrocarbons
http://en.wikipedia.org/wiki/Coal
"Coal is a readily combustible black or brownish-black sedimentary rock. The harder forms, such as anthracite coal, can be regarded as metamorphic rock because of later exposure to elevated temperature and pressure."
stealthiskey
« Reply #24 on: April 11, 2009, 03:55:40 PM »
dude you guys.  The sand blaster does not explode, trust me.  I've used it for many hours.  There is NOT even enough dust to pose a risk, it's not flammable, and the fluorescent light is not an ignition source.  The motor in the shop vac would be a bigger concern IF it was flammable at all.
That's like, if you lit a cigarette, on a beach, while the wind was blowing... you could blow up.  preeetty unlikely
seajay2525
« Reply #25 on: April 14, 2009, 09:59:11 PM »
I just got back from harbor freight, and their cabinets run $199. I'm not sure a 15 inch rim could fit in those very well.
« Reply #26 on: April 14, 2009, 11:17:54 PM »
kinda what i feel about their parts washers and an engine block or oil pan
