Author Topic: how bad are obx itb's?  (Read 20309 times)
« on: August 27, 2010, 02:32:53 PM »
Alright I hate to ask it but......................
Re: how bad are obx itb's?
« Reply #1 on: August 27, 2010, 03:20:24 PM »
If its for a gsr, buddy of mine has a set of almost brandnew jenveys for the cheap
« Reply #2 on: August 27, 2010, 04:13:45 PM »
I would kill for jenveys but its a itr head. If they are really cheap I could swap out the mani.
« Reply #3 on: August 27, 2010, 05:53:15 PM »
I have a read a few times that they will work well if you replace all the hardware (nuts and bolts) and use washers to take up some slop in the linkage.
« Reply #4 on: August 27, 2010, 05:55:57 PM »
I saw a set in person maybe 6 months back. The linkage set up is terrible and the springs they use are to weak to set the throttle plates back from wot back down to idle. Basically from what I looked at the car will never idle correctly with them and they are small for itb's anyways.
Just get a type r clone manifold+ported. More than enough
« Reply #5 on: August 27, 2010, 06:05:34 PM »
not an option, its either itbs or custom intake.
« Reply #6 on: August 27, 2010, 06:08:52 PM »
Honda motor, non honda chassis...
Still should have just done a boosted D.  :-*
« Reply #7 on: August 27, 2010, 06:24:20 PM »
Oem b16a manifold runners+box plenum welded on. Done. Easy cheap and works.
« Reply #8 on: August 27, 2010, 06:26:46 PM »
not unless there are some 90's or maybe 45's welded right after the injectors
« Reply #9 on: August 27, 2010, 06:29:14 PM »
the subframe will be setup for both b's and d's. It will have a turbo d in it at a later date. It waould be alot easier if it didn't need a intercooler  :-\
« Reply #10 on: August 27, 2010, 06:29:49 PM »
cooper?
« Reply #11 on: August 27, 2010, 06:33:13 PM »
cooper?
 ;) wait for build thread
« Reply #12 on: August 27, 2010, 06:52:20 PM »
If you need itb's just go with Jeff frank spec shit. Cut up an oem manifold/the biggest cycle itb's you can source aka busa's
« Reply #13 on: August 27, 2010, 06:54:31 PM »
well that the other plan but I was hoping for 240whp and I think the biggest is still too small. Boring is an option but then the price gets closer to just buying something.
PBT sponcership? lol
« Reply #14 on: August 27, 2010, 06:57:09 PM »
Yes if you want to sponsor me thats fine.
« Reply #15 on: August 27, 2010, 07:51:40 PM »
... I was hoping for 240whp...
So you are going turbo then.  :P
« Reply #16 on: August 27, 2010, 08:30:50 PM »
or just spend too much money and fail. (see plan b)
Super Dipper
  • Boost, Boobs, Beers
« Reply #17 on: August 27, 2010, 08:32:50 PM »
ha, im pretty sure what the  O0 is building.
Ill send you some pics of some guys have done out here Chad.
Formly Quadtech...
Team 4 MotorSports
« Reply #18 on: August 27, 2010, 08:33:45 PM »
great! did my brake diagnostics help you at all?
Super Dipper
« Reply #19 on: August 27, 2010, 08:38:34 PM »
residual pressure valves caused nothing but grief.
talked to wilwood techs this morning, turns out there is a goofy way to bleed a brake system with balance bars on the masters. spent a good while doing that today, seems to be doing better. Gonna road test it tmrw once i can figure out why the fuel pump circuit is blowing fuses randomly now...ugh stupid car, i just want it out of my shop. :(
Formly Quadtech...
Team 4 MotorSports
« Reply #20 on: August 27, 2010, 08:41:17 PM »
so thats a no, lol.  :-[
« Reply #21 on: August 27, 2010, 10:40:49 PM »
The only reason anyone should go NA is if some nog stole their turbo. Or they're swapping in a J-series.
« Reply #22 on: August 27, 2010, 11:20:29 PM »
Personally after doing the whole rhmt itb thing years ago, it was a really fun project but i gathered that it really wasn't worth it in the end unless your doing it for the sole purpose of fucking around and building shit. and buying a prebuilt set of itb's kinda defeats the purpose , right?
Although this winter i'm temped to build a custom set of 38mm or so itb's for the a6 with a custom plenum.(turbo is staying of course) might be fun, idk.
« Reply #23 on: August 27, 2010, 11:49:25 PM »
I'm doing it for lack of room. The car will weigh fuck all anyways, should still be quick, if it sucks I will stick the swap into a eg hatch and sell it to some douch bag to go built turbo d.
« Reply #24 on: August 27, 2010, 11:50:54 PM »
I didn't know they were THAT small, fuck that.
« Reply #25 on: August 28, 2010, 12:03:06 AM »
there only small if you think you can ONLY use 50mm+  itb's.
Super Dipper
« Reply #26 on: August 28, 2010, 01:14:19 AM »
not necessarily. Ill know more tmrw.
Formly Quadtech...
Team 4 MotorSports
« Reply #27 on: August 28, 2010, 01:29:01 AM »
Make a set of these.  It honestly doesn't look all too difficult
2slow
« Reply #28 on: August 28, 2010, 08:25:18 AM »
On ohmt jeff had a write up on how to do these on the old projects section.
« Reply #29 on: August 28, 2010, 10:29:00 AM »
no shit eh?
