Author Topic: how bad are obx itb's?  (Read 20300 times)
Re: how bad are obx itb's?
« Reply #30 on: August 28, 2010, 10:33:42 AM »
On ohmt jeff had a write up on how to do these on the old projects section.
Yeah we know.  ;D
« Reply #31 on: August 28, 2010, 12:55:51 PM »
they are small for itb's anyways.
I didn't know they were THAT small, fuck that.
there only small if you think you can ONLY use 50mm+  itb's.
45mm is not going to feed a high rpm 2.0l hoping for 240 whp worth a shit, if it would I would run bike shit over obx for higher quaility anyways.
« Reply #32 on: August 28, 2010, 02:30:38 PM »
Start doing your homework. Maybe some of the new cycle stuff got bigger from when i was doing alot of it. My assumption is they most likely did and can be bored 2-3mm larger
The only thing that will cost money is buying the cycle itb's+machine work. I still think it can be done for under 600 bucks even if you go the route of having the throttle bodies bored.
« Reply #33 on: August 28, 2010, 03:33:44 PM »
Iirc, it is quite common to bore out the 44mm zx-14 throttle bodies to 46mm.
« Reply #35 on: August 28, 2010, 03:46:25 PM »
M1000's run a pair of 50mm throttle bodies for a ~160hp so with 4 of them they should easily support the 240hp you are looking for.
« Reply #36 on: August 28, 2010, 08:57:40 PM »
Brett thats some good thinking right there  ;)
« Reply #37 on: August 29, 2010, 12:26:26 AM »
I really want this to be a turbo setup, but since you're so set on at least trying N/A, I might as well help out a bit...
For more options 2009-10 CRF450R's used 50mm throttle bodies too, the 2011's dropped down to a 46mm something about throttle response or marketing hype or...
raiden571
« Reply #38 on: August 30, 2010, 10:21:06 AM »
i have a set of custom itbs that will fit along with everything else like a fuel pressure reg, etc for that car. let me know if your interested.
Donald125
« Reply #39 on: September 01, 2010, 12:25:23 AM »
me love motorcycle power bands
(Thump, thump, thump) Stop resisting! (Thump thump thump) TAZER TAZER TAZER!
« Reply #40 on: September 01, 2010, 12:46:44 AM »
Holly shit man, havent see you in a while
« Reply #41 on: September 01, 2010, 08:33:09 AM »
Donald, sell chinese shit!  Nao!
