Author Topic: The Hotrex Dsm Air/water  (Read 11603 times)
« on: September 05, 2010, 11:27:40 PM »
Tried searching for it and no info I am going to jacket a dsm sidemount and use it air to water with an ac condensor and a hf pump anyways I heard hotrex did this a while back and I was curious if he(or anyone) has pics of it. I was curious how the jackets were ran and what the overall dimensions were.
yellow fever and a lil 18yo action
Re: The Hotrex Dsm Air/water
« Reply #1 on: September 06, 2010, 12:03:57 AM »
i have pics i was there when he hotrexed it with xenofraud... ill try to dig them up, probably tomorrow as they are on my external. pm me to remind me if they dont go up tomorrow.
« Reply #2 on: September 06, 2010, 05:32:59 PM »
Ideally you'd have the inlet & outlet on opposite corners from each other. If you beadblast it, you might get away with JB weld or devcon. A weld would be sketchy, since many smic's are old, corroded and oily, plus they are rolled & glued/brazed IIRC. FYI the real cores are small because the water passages are half the thickness. You'll get half the airflow in a smic vs a real core.
I might recommend a ebay radiator instead of the AC condensor. Roger McDaniels did that, plugged the original in/outlets, and welded nipples or AN fittings on it. You then get cap with an integrated overflow mechanism - good if you want to try a sealed system. I doubt you will with a RHMT core...
« Reply #3 on: September 06, 2010, 07:23:14 PM »
I so want to make one of these.
mrgreengenes
« Reply #4 on: September 06, 2010, 07:38:22 PM »
I did one of these a few years back, worked well... it differed from hotrex's setup where i had the charge air go through the ambient air passageways...
Pics
air inlet
SDRAWKCAB
  • D series BALLA!
  • Rhino
« Last Edit: September 07, 2010, 03:21:42 PM by SDRAWKCAB »
« Reply #6 on: September 11, 2010, 06:45:41 PM »
i had to leave on my trip before i could dig up my picd ill look on facebook but i think the pics are older than facebook lol
« Reply #7 on: September 11, 2010, 10:50:49 PM »
That looks like a good idea. It would have much better airflow, but still enough cooling power. At this point the prefabbed IC's are cheap enough, unless you have welding skills and a $1500 tig.
« Reply #8 on: September 11, 2010, 11:26:13 PM »
Or lots of JB weld.  Its not like the fucking thing is gonna get very hot.
