Author Topic: Tubing coping calculator... -  (Read 12106 times)
walter
« on: September 08, 2010, 03:18:11 PM »
what setup do i would can use for make a 4-1 collector? ill use 1.5  - 1.89OD .101thick steel.
i tried this:
Diameter 1
(cut tube) : 1.89
Wall Thickness
(cut tube) : 1.89
Diameter 2    : 1.5
Angle : 45
Offset : 0
i'd like some of you guys can help me with this, just i'd like to have this marked for begin cut pipes by tomorrow. ill make a cheap Ramhorm for my Z6 reubild in EF civic.
Hope your help!
walter
Re: Tubing coping calculator... -
« Reply #1 on: September 08, 2010, 05:00:26 PM »
« Reply #2 on: September 09, 2010, 02:37:54 AM »
thats for making fish mouth cuts in round tubing.
all you need to do is set the saw for 12 or so degrees, make 1 cut. then spin the tube 90 degrees and make another cut.
i know theres a write up on here.
« Reply #3 on: September 09, 2010, 02:38:44 AM »
walter
« Reply #4 on: September 11, 2010, 09:52:55 AM »
I only have this  :-\
Uncle Fester
« Reply #5 on: September 11, 2010, 10:54:53 AM »
A HF chop saw (under $100) and a jig can do it. I wouldn't even try it with an angle grinder.
2slow
« Reply #6 on: September 13, 2010, 12:52:39 AM »
I've tried it with an angle grinder but it never works out well
