Author Topic: Custom taillight leds  (Read 9659 times)
walter
« on: April 09, 2009, 08:01:19 PM »
hi, i was looking for make my own custom taillight leds for my civic EF 90 hatback.
Im waiting already for PCB board (12) i ordered for leds.
the problem i have right now is about leds, i was looking on ebay and found this:
http://jbrlsr.com/?aid=5336118848&bid=3196509&url=http%3A%2F%2Fjbrlsr.com%2F%3Faid%3D5336118848%26bid%3D3196509%26url%3Dhttp%253A%252F%252Fcgi.ebay.com%252F100PCS-8MM-SUPER-BRIGHT-RED-DIFFUSED-LED-LAMP-NEW-F-R_W0QQitemZ190213460316QQcmdZViewItemQQptZLH_DefaultDomain_0%253Fhash%253Ditem190213460316%2526_trksid%253Dp4634.c0.m14.l1262
I want to make tailight and turn signals..so i was in the point to order 100 red leds, 50 white leds and 50 yellow reds, they say includes resistor for working on 12V so should works on the car.
The problem is about if those will works just installing each resistor to each led , i means if they will works with brake light too , if they will bright more of do i need another resistor or what really ill need.
i found this ones too with more MCD
http://cgi.ebay.es/100X-New-5mm-Super-Bright-Red-LED-Lamp-35-000mcd-FS_W0QQitemZ250402368429QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item250402368429&_trksid=p3911.c0.m14&_trkparms=72:1315|66:2|65:12|39:1|240:1318
Ill appreciate a lot any input/help
Thanks
« Last Edit: April 09, 2009, 08:07:20 PM by walter »
walter
Re: Custom taillight leds
« Reply #1 on: April 09, 2009, 08:22:43 PM »
i assume ill not get any help there..
thx.
« Reply #2 on: April 09, 2009, 08:29:58 PM »
If you set it up as a series paralell circuit, you need one resistor per series circuit.  That way, if one burns out, it will only render one series of LED's inoperative.   Either of these circuit types should work
« Reply #3 on: April 09, 2009, 08:31:27 PM »
Obviously not 24v
The first circuit will isolate any LED should it burn out so that it is the only one that will be out, however the extra current is added to the LED's that are paralell to the one that burned out and if not maintained could burn the rest out.
I would try a variable resistor to determine your brightness,  Start off with the highest restatance and progress down till your happy with the intensity.
« Last Edit: April 09, 2009, 08:35:53 PM by Conceptz-X »
walter
« Reply #4 on: April 09, 2009, 08:56:48 PM »
thx for your help
really i have not much idea about how to do this, i know weld and so but, then, what leds of links i post above should i buy? they comes with resistence for works on 12V, if that enought for this?
« Reply #5 on: April 09, 2009, 09:24:25 PM »
If your wanting to try it, go for it.
This half-assed diagram I made might give you an idea on how to wire it.  I can help you out more later if you decide to do it.
turbogeek
« Reply #6 on: April 09, 2009, 09:27:27 PM »
you been here yet?
search it and you'll find everything you need to know.
http://www.hidplanet.com/forums/
jap bitches: for when no other cumdump will do the sick thing you just thought of
« Reply #7 on: April 09, 2009, 09:35:55 PM »
This isn't a Rick P forum is it?  I see you need to sign up to get acess to the threads
You need a NOOB post even if you bring good info
walter
« Reply #8 on: April 10, 2009, 07:56:04 AM »
nice! ok, i was talking with a guy that do samething on antoher car.
said me he used a LM317 for dual bright.. he used one with regulator for get bright i need and low to 6v for low I and for brake like i assume 12v or so.
i was learning yesterday about this things (i like this kind of electronic lol) and made this for know what resistor i need for low to 6V
and:
12-6/0.020A (20mA is use LED, says this on description): and i got 300ohm.
ok then using a LM317 with 300ohm for get 6v is Ok if im right, but what i dont know is how to connect it, well really i think i know how should go
civic has two wires for low and brake light, so ill need two LM317s?
walter
« Reply #9 on: April 10, 2009, 08:01:31 AM »
btw, i ordered already 250leds ( 100red, 100 yellow and 50 white ones) and PCBs boards are in the way going here.  :yes:
ill do it for sure.
« Reply #10 on: April 10, 2009, 10:01:58 AM »
well i want to see a write up
« Reply #11 on: April 10, 2009, 10:48:14 AM »
In for a write up when you get there. ;D
hotrex
« Reply #12 on: April 11, 2009, 01:44:51 AM »
this a serious waste of ur time and money. good thing your a worthless euro faggotniglitanus
« Reply #13 on: April 11, 2009, 01:58:54 AM »
Sorry I think your the most worthless person on this site with your crack mani's and fail shipping skills :P
« Reply #14 on: April 11, 2009, 02:08:11 AM »
s L a W j C: wanna hear a funny joke?
BoostedSchemes: sure
BoostedSchemes: i hope its about aids
s L a W j C: i charged u full price for a piece of shit nigger log manifold i welded at 2am piss drunk and with a chinese tig and no filler rod.   i then used that money to buy supplies to build 3 more manis niggas paid for and never got
BoostedSchemes: thats not a joke, thats business
s L a W j C: i had a hard time looking at you when i handed over that steamy pile
s L a W j C: then i realized you were russian and u deserved it
« Reply #15 on: April 11, 2009, 02:10:43 AM »
god were we dying when he wrote that. i couldnt breathe for 5 mins.
« Reply #16 on: April 11, 2009, 02:20:06 AM »
I used to be amused when he would bring it up every few weeks but he keeps changing the story so its not as funny knowing half the time he's just spewing shit so people find him amusing  :?:
« Reply #17 on: April 11, 2009, 02:35:21 AM »
the first half was true, there were witnesses to that.
hotrex
« Reply #18 on: April 11, 2009, 02:44:39 AM »
i get bukwild in your moms paraneum
walter
« Reply #19 on: April 12, 2009, 05:15:08 PM »
 :D
