Author Topic: Cracked manifold advice  (Read 16730 times)
SgtB
« on: September 11, 2010, 05:00:29 PM »
Installing a new compressor on my wife's civic Lx and found this shit peaking out from behind the heat shield. Fuck.
I'd like to MIG it but I am not %100 on cast. I know to drill the ends of the cracks,notch the cracks, and to heat it. Question is can I use a propane torch to heat the area, or is that not hot enough? Also can I heat one side (in reference to the o2  sensor port) at a time, or is it critical for the entire piece to be hot. I have a charcoal grill. I'll bbq this bitch in a heartbeat if I have to. Thanks.
Re: Cracked manifold advice
« Reply #1 on: September 11, 2010, 05:34:19 PM »
5 dollar junkyard donkey punch.
skaterdudz02
« Reply #2 on: September 11, 2010, 05:53:55 PM »
Dude just use as much heat as you can and weld the bitch shut. It'll be fine and do the job for another 100 years.
SgtB
« Reply #3 on: September 11, 2010, 05:57:11 PM »
I wish. There's no civics around here, and I'm trying to get this thing back together asap. Car's going to LA in a week.
Can I really just weld it? I thought cast likes to crack.
Ravage70
« Reply #4 on: September 11, 2010, 06:22:19 PM »
Fluxcore on High 2.
Stop being a baby!
Hotrodlincoln
« Reply #5 on: September 11, 2010, 06:28:25 PM »
O/A Braze!
kill yourself piss face
TTC
« Reply #6 on: September 11, 2010, 07:12:08 PM »
We put my buddies in the oven for an hour then migged the fuck out of it. Still holds.
SgtB
« Reply #7 on: September 11, 2010, 08:15:05 PM »
Fluxcore madness complete.  :)
Wasn't as bad as I thought. I drilled the ends because I'm chickenshit, and then just hit it on wtfo on my little 140amp. I was a little apprehensive when my root pass crazed.  :o I just figured I should have pre-heated it and the cast was pulling it apart. I  switched into glue-gun mode and everything went good after that.
I was all worried about the cast. Never thought the weld would be the problem. ??? I left my auto hood at the shop too, so I had to do this shit one handed with a jumbo plate in one hand, and my hair melting off. ;D
« Reply #8 on: September 11, 2010, 08:46:31 PM »
This is what its all aboot....
« Reply #9 on: September 12, 2010, 10:19:48 AM »
Looks great, good job!
SgtB
« Reply #10 on: September 12, 2010, 12:53:48 PM »
Thanks.
Couldn't quite get the landing right after a few fill and grind runs so I grabbed an old crush washer from my s2000's diff out of the catch pan. Shit fit perfect and sealed everything right up.  :yes:
« Reply #11 on: September 12, 2010, 01:00:26 PM »
