Author Topic: hydroplane racing  (Read 13941 times)
hydroplane racing
« on: September 15, 2010, 02:36:10 PM »
On my down to sandeago for some hydro plane racing this weekend.should be a lot of fun lots of big and little hydros. Stop by and say hi if you in the area. Me and josh will be working on the gp-99 all weekend
Re: hydroplane racing
« Reply #1 on: September 15, 2010, 03:38:11 PM »
hit up n/a mike!
« Reply #2 on: September 15, 2010, 03:40:36 PM »
hit up n/a mike for Hot Pockets and fat bitches.
« Reply #3 on: September 15, 2010, 10:45:23 PM »
i could go for a hot pocket  :D
« Reply #4 on: September 15, 2010, 10:47:00 PM »
hit up n/a mike!
that's the last thing i'd fuckin do.
Cadracer
« Reply #5 on: September 18, 2010, 06:30:25 PM »
 ;D cool  At my shop where i was  these guys are there. roostertailracing.com
Was there when they just put in the new motor.Guys are cool   I rent the same place they do. We have a few  beers on the weekends when there there working.  :o There in calli  testing the new  hydro the just got finish putting together
« Reply #6 on: September 19, 2010, 01:27:02 AM »
2 motors this weeknd so far. ouch.
« Reply #7 on: September 19, 2010, 07:55:55 AM »
um....as far as i can tell that motor has no intercooler? why dont they run one of those water/air ic's that go between the blower and manifold?
or are they running meth?
« Reply #8 on: September 19, 2010, 08:10:02 AM »
Straight Alcohol.
« Reply #9 on: September 19, 2010, 08:55:23 AM »
but still couldnt you run a water/air ic and have awesome air temps. or with alchy is it not much of a difference, im not really familiar with the fuel.
« Reply #10 on: September 19, 2010, 11:44:54 AM »
They usually have plenty of power as it is. It's a matter of getting the prop to bite and keeping the hull right on the edge of control.
rob91da
« Reply #11 on: September 19, 2010, 11:45:01 AM »
Alex is actually down there just fucking dudes in San Fran. Don't fall for the hype.  :noel:
N1 Andy
« Reply #12 on: September 19, 2010, 11:54:07 AM »
Actually Alex is down in San Diego at a Spelling Bee.  He's not expected to do very well.
GFIgarage
rob91da
« Reply #13 on: September 19, 2010, 12:01:42 PM »
 ;D ;D This is fact!!! haha
« Reply #14 on: September 19, 2010, 02:46:16 PM »
My god, that has got to be making some serious power.
« Reply #15 on: September 19, 2010, 03:51:18 PM »
if you put rubbing alcohol on your hand its cold much the same when it gets injected into an intake manifold.
Some tractor puller and drag racing guys have a problem of icing up the intake due to a lot of fuel at very high pressures.
an I/C would cause the situation to be worse.
When I ran my dsm on straight ethanol (scored from work) i didnt run an intercooler and after a run my intake manifold depending on weather was either
slightly warm to damn near freezing. I am planning on running a lowish boost setup on e85 with either a air/water or no I/c at all
narfdanarf
« Reply #16 on: September 19, 2010, 04:34:43 PM »
If I keep my car an outlaw car, I'm ditching the intercooler and BOV.  I don't think it's worth the 40lbs for what I get on a drag only car.
Cadracer
« Reply #17 on: September 19, 2010, 07:41:54 PM »
the motor make 1500hp and  he says the intake charge doesnt get above 120 degrees  alchol injected
« Reply #18 on: September 19, 2010, 07:59:01 PM »
Its kinda the same thing how c02 or propane tanks get cold when they vent something going from high pressure liquid to low pressure vapor with pull
heat out of the surrounding air to vaporize the liquid thus cooling the charge. think nitrous
« Reply #19 on: September 19, 2010, 08:22:06 PM »
endothermic heat transfer.
« Reply #20 on: September 19, 2010, 08:50:11 PM »
Sounds like a bad fart
« Reply #21 on: September 20, 2010, 04:53:41 PM »
Man you guys missed out. It was a blast! Ill post some pics and info when I get home
« Reply #22 on: September 23, 2010, 02:46:48 PM »
vary cool boat/ guys they were next to us in the pits, they took 1st in the 4th heat of the weekend all becus everyone else way DQ.that boat did well for being 3/4 done
