Author Topic: Rod lenght for EF (Tracion bar kit Weir)  (Read 26514 times)
walter
« on: September 17, 2010, 01:06:14 PM »
What title says, ill got a traction bar kit from Weir 1.5", im looking for tube and i was wondering what lenght should i buy for my  Civic 90.
Re: Rod lenght for EF (Tracion bar kit Weir)
« Reply #1 on: September 17, 2010, 06:22:38 PM »
any length sign post will do
« Reply #2 on: September 17, 2010, 06:35:06 PM »
Just buy tubes and cut them to fit.
« Reply #3 on: September 17, 2010, 08:02:06 PM »
I got mine from chris m, he knows the size.
walter
« Reply #4 on: September 18, 2010, 08:45:06 AM »
 i means strud rod , bar , link , linkage or whatever shit is called in english.. ill ask to Weir but if you know it will help me alot.
Thanks
walter
« Reply #5 on: September 18, 2010, 09:08:39 AM »
ok, it's radius arm  :?:
« Reply #6 on: September 20, 2010, 01:54:17 PM »
« Reply #7 on: September 20, 2010, 05:06:17 PM »
i HAVE 2 tHREADED RADIUS RODS (ALUMINUM) WITH 5/8 HEIMS ON BOTH ENDS. 19" LONG.
« Reply #8 on: September 20, 2010, 05:44:32 PM »
Im almost 100% sure that that is about 2" to long.
« Reply #9 on: September 20, 2010, 06:07:15 PM »
Fuck it, cut them. LOL
« Reply #10 on: September 20, 2010, 07:01:50 PM »
Get 4' of tubing,
2 rht 5/8" nuts
2 lht 5/8" nuts
2 heim joints 5/8" rht
2 heim joints 5/8" lht
Cut tubing to lenght and weld the nuts in the end. Done!
« Reply #11 on: September 21, 2010, 06:36:58 PM »
Do this!  http://www.realhomemadeturbo.com/forum/index.php?topic=6103.msg175667#msg175667
5/8 is pretty big though.  I think 1/2 is actualy the right size.
walter
« Reply #12 on: September 23, 2010, 12:51:59 PM »
thanks !!
got already weir flanges, 2 days in Spain from Canada.  :noel:
« Reply #13 on: September 23, 2010, 04:02:36 PM »
jeez guy....
use the search function!  :P
http://www.realhomemadeturbo.com/forum/index.php?topic=137.0
16in radius rod, 38in bar across.
« Reply #14 on: September 24, 2010, 05:32:44 AM »
search button in english no help wannabe mexican walter
« Reply #15 on: September 24, 2010, 07:54:37 AM »
I need to make one of those to put on my Integra. I hate that fucking huge crossmember.
walter
« Reply #16 on: September 24, 2010, 08:59:21 AM »
Im not mexican. sometimes i dont understand english because a lot of you dont know how to write it correctly.
ill order bungs and Dom tube next week!
« Reply #17 on: September 24, 2010, 10:33:05 AM »
Your wrong dud. I can rite anglish. As wel as yoo doo.
walter
« Reply #18 on: September 24, 2010, 05:57:12 PM »
sure...  :?:
« Reply #19 on: September 25, 2010, 06:03:32 PM »
his franch-canook, dunt mine hes pour anglesh.
BTW anyone know what size "radius rod" would work decent for an EG traction bar? I want to make my own, but I'm thinking swagged tubes from Summitracing.
« Reply #20 on: October 01, 2010, 03:08:07 AM »
do you really need the dom tubing, i though all that did was make the pipe smooth
« Reply #21 on: October 01, 2010, 03:31:30 AM »
For traction bars, DOM would be overkill. DOM is the process used on a given steel, which makes almost all it's properties better. The load is mostly near the ends, so it just needs a decent weld. DOM tends to be easier to find in a specific OD w/better tollerances.
walter
« Reply #22 on: October 02, 2010, 05:35:07 PM »
what OD/thickness would be recemmended?
« Reply #23 on: October 04, 2010, 01:31:00 PM »
get SCH80 1/2in
it is plenty thick
