Author Topic: just got back from the track  (Read 12292 times)
shanerv
« on: September 18, 2010, 12:34:09 AM »
so I finaly got my self up to the local track nyirp in liechester ny, pretty nice track for the location.
setup
95 gsr stock suspension
stock trans open diff. and exedy stage 1 organic clutch
stock block with rebuild 40k ago  and boosted for last 30k
arp head studs and a port and polish on the exhaust side
holslut hc1 running at 11.7 psi and the egay super crack manifold welded 10x over
dsm 450s with the stock fuel pump and a xeno base map (been rockin it for 1and half)
borrowed M&H race masters on lenzo rims 22x8 11psi
car ran great and did consistant 12.5's @112.7
pulled some 1.8 60ft times pretty consistant to even did that with a passenger in the car.
had a few questions for the experienced guys out there what are the chances of cutting a better 60ft with a stock suspension? it's all stock now with 150k
and since this is my dd and I comute like 100 miles a day to work how much power should I shoot for when I get this thing dynoed hopefully in november and still make it a safte dd.
Re: just got back from the track
« Reply #1 on: September 18, 2010, 01:45:02 AM »
You can cut a 1.7 maybe even a 1.6 on stock suspension. UI cut a 1.6 on chinky coilovers.
SOHCKLR657
« Reply #2 on: September 18, 2010, 02:34:37 AM »
Timeslip Or It Didnt Happen.... :noel:
2slow
« Reply #3 on: September 18, 2010, 03:37:45 AM »
« Reply #4 on: September 18, 2010, 06:59:10 PM »
So you race with a passenger? OK
shanerv
« Reply #5 on: September 18, 2010, 07:00:54 PM »
you wanted proof you got it. 12.502 and 12.572
shanerv
« Reply #6 on: September 18, 2010, 07:03:18 PM »
I do race with a passenger sometimes. track got pissed though they only allow passengers up to 13.99 I shut it down to late with the one passenger. but they are pretty cool around here.
also the numbers on the slip are supposed to be 28 on both but the track messed up and put 48 on the one.
« Reply #7 on: September 18, 2010, 09:10:13 PM »
so you sleep for almost a second on the tree?
A 13.3 car would beat in a race :)
Sounds like you didn't get enough heat into the M&H's, psi too high, or launched like a pussy :)
shanerv
« Reply #8 on: September 19, 2010, 09:51:09 AM »
ya I wasn't really worried about the tree I was letting is spool up so it wouldn't bog off the line.
I was runing 11psi in the slicks you can hear them slipping thru most of 1st 2nd and 3rd they  are like 5 years old too ha
the lauch ehh. I have like to let it out not droping it but in between dumping and a fast street lauch.
« Reply #9 on: September 19, 2010, 11:27:34 AM »
Good numbers
accordepicenter
« Reply #10 on: September 20, 2010, 08:16:07 PM »
I can vouch.  He shut down well before the traps and we still went 12.9 with me riding shotgun.  Oops.  Shane I think its time for a 255lph walbro and bigger injectors :)
shanerv
« Reply #11 on: September 20, 2010, 11:58:11 PM »
ya and a tune for the first time in my life haha  " I rock a basemap and probably will for life"
but in this case b series 12 lbs will turn ya out.
« Reply #12 on: September 21, 2010, 12:56:44 AM »
Needs more boobs, too much weenus grabbing going on here.
« Reply #13 on: September 21, 2010, 04:15:41 PM »
Needs more boobs, too much of me grabbing weenus here.
shanerv
« Reply #14 on: September 21, 2010, 05:53:12 PM »
what do I look like a rhmt noob? I have been around hmt since near it's inception. boobies are in the pron section.
« Reply #15 on: September 21, 2010, 06:18:19 PM »
This is RHMT sir, we have bobbies everywhere
shanerv
« Reply #16 on: September 21, 2010, 06:30:40 PM »
this is true. but not from me. tryin to keep it clean and about what it's supposed to be racing and the love of boost.
accordepicenter
« Reply #17 on: September 21, 2010, 10:26:09 PM »
Bobbies?  Get the rope...
« Reply #18 on: September 21, 2010, 10:34:58 PM »
Kill yourself
« Reply #19 on: September 21, 2010, 11:21:20 PM »
With that attitude you will not make OG status and Wednesday is almost here. :?: ;D
shanerv
« Reply #20 on: September 21, 2010, 11:31:35 PM »
bring the ban hammer on haha.
SgtB
« Reply #21 on: September 21, 2010, 11:33:47 PM »
When rHMT asks for porn, you deliver. It's non-negotiable.
That took 30 seconds. Stay Wednesday.
« Reply #22 on: September 22, 2010, 12:38:05 AM »
If you were around for the inception, you should have the pr0nz smashed into your brain meat by now. I was just saying that porn makes any dull thread inherently good. Then REFUSE to post pron, that is just a slap in the face of every OG here.  But you know that since you feel that you are an OG.
« Reply #23 on: September 22, 2010, 12:44:17 AM »
Just a little start;
