Author Topic: How do you know when a wideband o2 sensor is bad?  (Read 70451 times)
DmC
Re: How do you know when a wideband o2 sensor is bad?
« Reply #30 on: May 05, 2009, 12:00:27 AM »
fuck the LC-1.  i have a first run, it sucked ass.
It's still more accurate than that AEM POS you have.
Also, Klaus warranties all of his defects.  It doesn't matter if you are the original owner, have a receipt, etc, if it's one of the early ones with the glitchy analog outputs consider it replaced.
Dude Phillipe is a good guy to. Innovate has repared my lm-1 twice. Both times it was my fault but there were no questions asked on their end they just fixed it and sent it back.
« Reply #31 on: May 09, 2009, 04:07:35 AM »
i love my LC-1... never had any problems and made sure to flash the firmware
been running it for over a year w/o issue
rudebwoy
« Reply #32 on: May 10, 2009, 11:40:27 AM »
zeitronix ownz all , and uses the same o2 sensor as 17014. when I have a bad o2 sensor it automatically goes to full lean after warmup. www.zeitronix.com
« Last Edit: May 10, 2009, 05:14:48 PM by rudebwoy »
DmC
« Reply #33 on: May 10, 2009, 02:18:30 PM »
zeitronix ownz all , and uses the same o2 sensor as 17014. when I have a dad o2 sensor it automatically goes to full lean after warmup. www.zeitronix.com
Man that doesn't look to bad. I wouldn't mind trying one out.
