Author Topic: LS rod mod bushing size?  (Read 11323 times)
JohnHandcock
Re: LS rod mod bushing size?
« Reply #1 on: October 05, 2010, 01:15:11 AM »
metric.......
« Reply #2 on: October 06, 2010, 01:08:38 AM »
21mm is the titular size of the B-series small end, for a press fit pin.  You want a free floater... which means you can press fit to the rod if you want, but shit better slide smooth and precise somewhere.
« Reply #3 on: October 06, 2010, 10:22:02 AM »
UMM...... this isn't something you cheap on.
Call crower say what you need/ are doing. they send bushings to you or machine shop of choice. Then the machine shop does there thing. And make sure they  hone to fit the bushings.
« Reply #4 on: October 06, 2010, 11:30:35 AM »
You very much can cheap out on it, but it involves a $400 investment in an asian mini-lathe, and about twenty hours of fucking around getting it trued up and fucking around with shit before you purchase $10 worth of oil impregnated brass + make 2-3 sets of these.  Probably fuking them up if you don't pay attntion to clearances.
« Reply #5 on: October 06, 2010, 03:59:04 PM »
sounds about how i do things, spend $2k to weld up a log manifold. but you did it for cheap. haha
« Reply #6 on: October 06, 2010, 04:25:39 PM »
That $150 starts to dwindle down to almost nothing by the time you weld up 20-30 different little projects
« Reply #7 on: October 06, 2010, 11:20:40 PM »
It's a free welder now
« Reply #8 on: October 06, 2010, 11:58:35 PM »
or know someone who can do inside/outside grinding on small parts.
