Author Topic: CEL 43 Help?  (Read 13059 times)
Full Spool
CEL 43 Help?
« on: October 06, 2010, 07:00:36 PM »
The car is a 2000 si with b20 block and si head, and a crome base map. While cruising the interstate the CEL will come on and then go away when the car is turned off. It comes on almost evertime on the interstate. My crappy helms manual states check fuel supply, regulator and vacuum lines. I have checked all of that fuel psi is around 45psi at idle, and im at a loss on where to begin from here. Any suggestions?
p28 clone obd1 ecu, I've tried a few different maps on different chips with same results.
Re: CEL 43 Help?
« Reply #1 on: October 06, 2010, 07:07:00 PM »
I got the same when I had Al shavings, and wiring harness was damaged.  O0
I believe the ECU picks up the issue when one of the inj. wires from the ecu A-plug is damaged.
That is what I would look at if you have already looked at the FPR, FP, fuel filter, and vac. lines.
Did you use low impedance inj. and a resistor box in this setup?
If so I would look at the solder wires at the resistor box also. :yes:
Re: CEL 43 Help?
« Reply #2 on: October 06, 2010, 07:22:08 PM »
I think I got this CEL too last week but haven't search about it. Good thing to know.
Re: CEL 43 Help?
« Reply #3 on: October 06, 2010, 07:56:47 PM »
I learned this this summer  :-\
Full Spool
Re: CEL 43 Help?
« Reply #4 on: October 06, 2010, 10:43:55 PM »
It has stock injectors in it now, the car has been a wiring nightmare and hacked into by some ricers.
A new engine hardness has been installed along with stock injectors, it does have a CDM ebay conversion harness so I will check the pins as suggested! Thanks man.
Re: CEL 43 Help?
« Reply #5 on: October 06, 2010, 10:50:38 PM »
The cell happen after a run at WOT and some boost. Maybe it's due to the vibrations from the engine?
Full Spool
Re: CEL 43 Help?
« Reply #6 on: October 06, 2010, 11:00:18 PM »
Its an NA car, it only happens in 5th gear cruising at 70-75 on the interstate.
Re: CEL 43 Help?
« Reply #7 on: October 07, 2010, 06:14:04 PM »
You should post questions like this in the EM forum.
Full Spool
Re: CEL 43 Help?
« Reply #8 on: October 07, 2010, 11:17:02 PM »
I did originally but a mod moved it.
Re: CEL 43 Help?
« Reply #9 on: October 09, 2010, 06:55:38 PM »
Boost will most asuredly make it go away. DO WORK.
Full Spool
Re: CEL 43 Help?
« Reply #10 on: October 11, 2010, 12:11:23 PM »
No boost, it isn't my car. I don't drive honduhs anymore.
