Author Topic: need computer help formating  (Read 5339 times)
« on: October 24, 2011, 10:57:45 PM »
Long story short I lost my 1.5 yr old Sony laptop in a fire (an a ton of other shit) and now I'm trying to get my 5 yr old dell to work decent. it's got a bunch of crap on it. I have the legit windows xp code for this laptop. I just bought a new jump drive. I need a link of where I can download xp, so that I can format, plug in my jump drive, and install xp from it.
jay
Re: need computer help formating
« Reply #1 on: October 24, 2011, 11:07:22 PM »
fuck your legit code
you will need bittorrent (www.bitttorent.com)
then go to piratebay.org
download windows xp via bit torrent. it will be in an ISO format.. which is a disk image
then use a program called universial usb installer (http://www.pendrivelinux.com/downloads/Universal-USB-Installer/Universal-USB-Installer-1.8.6.8.exe)
select the windows xp iso
select windows xp
if you dont care about the shit on your flash drive select reformat flash drive
put it into the computer you want to reformat
either run it off the installer through windows
or if that doesnt work restart the computer with the flashdrive in it
keep pressing f12 till you get into the boot menu and select the usb flash drive
i suggest you download a program called driver magician from pirate bay first...
install it and run it then copy the drivers onto the flash drive after you install xp onto it
that way you have all your drivers
I want you to die
« Reply #2 on: October 25, 2011, 09:30:17 AM »
How bad of a fire was it? dcfldd has brought back more shit then most people thought could not.
« Reply #3 on: October 25, 2011, 07:07:46 PM »
Software is great for bringing back data that hasn't been written over multiple times and was just recently deleted.
Software does not do a good job with damaged hardware.
If the drive isn't melted from the heat you can probably get some back, but if it is than you can forget about it.  Heat also demagnetizes shit, like hdd platters.  If the drive won't spin, you could find a clean-room, find a similar model, and swap the platters (be careful!).
