Author Topic: e85 miss in cold  (Read 9037 times)
e85 miss in cold
« on: November 18, 2011, 06:00:48 AM »
the tercel is running e85, around a 11:1 gas afr( that means its still using the gas calibration) at about 10 psi on a td04.
problem is all of a sudden when it got cold out(went from like 70's to 20's in like a week) im now getting a miss. AIT's are like 50 degrees at 10psi. ran fine when it was 70+.
gonna buy some new plugs and gap them closer, do you think this will solve the problem? do i need to run a hotter plug? change timing?
ive heard that e85/e70(winter blend around here) is just too cold of a fuel combined with cold air.
any experience with this?
Re: e85 miss in cold
« Reply #1 on: November 18, 2011, 09:38:04 AM »
Insufficient information.
« Reply #2 on: November 18, 2011, 12:45:04 PM »
Aim an electric heater onto your gas tank til gas temps are 30F warmer. Check car again.
All the vids I've seen about Brazil cars is they have a auxilury cold-start tank of regular gas, and the exhaust is routed to heat up the e85 gas tank. You could build the exhaust like on my civic, where the e-cutout dumps right onto the gas tank.
« Reply #3 on: November 18, 2011, 03:07:40 PM »
Cue stock RB25 AEM calibration startup screen vs 1000cc E85 AEM calibration startup screen.
« Reply #4 on: November 18, 2011, 08:28:49 PM »
I'm not baller enough to do that, but I know e85 startup fuel trims are expotentially higher vs gasonline.
« Reply #5 on: November 18, 2011, 09:08:54 PM »
ok more info?
toyota 5efe
decapped wrx injectorators
megasquirt
stock ignition with a bosch smart igniter
ngk's at .044''
probably e70
dont know what else
titties?
« Reply #6 on: November 19, 2011, 07:11:45 PM »
This may sound dumb but have you tried reducing the plug gap? Am I to presume it's also the stock heat range for that plug? That could also play a part in this.
« Reply #7 on: December 18, 2011, 11:23:04 PM »
well ive been pretty busy lately but i did throw new plugs in the car that i gapped at .022 and i havent had a miss for a couple weeks.
side note, 40 degree MAT's are awesome O0
