Author Topic: Weird whining sound over 9 psi WTF?!?!  (Read 18636 times)
RACEPAK
« on: January 02, 2012, 07:49:57 PM »
hey guys, so i installed a used turbo kit for a friend and we have a wierd whining sound when we hit 9 psi, it sounds like when you squish the end of a full baloon, or farting really fast from a small ass:)
this is an example of the sound on a srt 4:
SRT4 weird noise under WOT boost
i'v checked for vacume leaks and fixed everything,
tested the charge pipes for leaks,
replaced 3 blow off valves.
holds 10.3 psi like a champ.
anyone have an idea? first time i hear this type of noise on a car :S
my next tests are fuel pump/pressure. and the oring inside the compressor housing,
thanks
« Last Edit: January 02, 2012, 07:52:49 PM by RACEPAK »
Re: Weird whining sound over 9 psi WTF?!?!
« Reply #1 on: January 02, 2012, 08:10:00 PM »
Pressurize the whole system at once. Probably a boot that is leaking.
« Reply #2 on: January 02, 2012, 08:14:00 PM »
RACEPAK
« Reply #3 on: January 02, 2012, 08:18:20 PM »
i did it, no air is leaking, from the charge pipes
i will check for leaks behind the compressor tommorow.
« Reply #4 on: January 02, 2012, 08:31:06 PM »
That's a turboqueef
« Reply #5 on: January 02, 2012, 10:43:29 PM »
Something has to be leaking.
« Reply #6 on: January 03, 2012, 01:54:01 AM »
Why are you taking rippers on a car with a CEL?
« Reply #7 on: January 03, 2012, 08:02:02 AM »
I believe that's not the car in question, just a video he found making the same noise.
« Reply #8 on: January 03, 2012, 11:35:57 AM »
Piss wiffle.
« Reply #9 on: January 03, 2012, 01:03:03 PM »
Either the turbo is unbalanced, or something like a pcv valve is leaking oddly. How about a leaky wastegate?
RACEPAK
« Reply #10 on: January 04, 2012, 09:34:14 AM »
the pcv valve is drilled out and routed to the catch can along with the valve cover breather.
i think the turbo is good the spool sounds clean,
well. i tested the fuel pressure today (the car has a walbro pump fused and relayd from the battery and a OEM fpr,
the gauge shows 50 psi at idle, and it dosnt change when i dissconnect the vacume line,
it also dosnt change when i drive the car. odd one,
« Reply #11 on: January 04, 2012, 09:58:21 AM »
What OEM FPR?  SRT-4 are a factory returnless setup.
« Reply #12 on: January 04, 2012, 10:11:41 AM »
Funny how smart people can be so oblivious.
There is no srt-4.
« Reply #13 on: January 04, 2012, 11:23:33 AM »
« Reply #14 on: January 04, 2012, 12:52:18 PM »
There is no srt-4.
I'm trying to have fun here.
« Reply #15 on: January 04, 2012, 01:26:30 PM »
Good cover
RACEPAK
« Reply #16 on: January 04, 2012, 06:37:32 PM »
solved:
it was the damn chinese plastic "T" from a fake hks bov that i used to increase boost for tuning,
one of the ports was closed!!!!!! :S
so the wastegate was closed all the time and the compressor port boosted out from the open side of the T, thats what caused the whistle!
i could never know it since i set boost cut for 10.3 psi :S
thanks guys!!!!!!11
