Author Topic: Anyway to bench test alternators?  (Read 11001 times)
« on: January 03, 2012, 04:07:23 PM »
I know take it to the parts store to get tested but I dont know how many times one place says one is bad and take it to another store and they say it's good. I know how to do it on the car but I get tons of parts cars that are missing parts/stripped etc so I cant just test them the old fashion way with the engine running.
Re: Anyway to bench test alternators?
« Reply #1 on: January 03, 2012, 04:43:46 PM »
The only other way is make a testing stand.  :noel:
« Reply #2 on: January 03, 2012, 05:38:08 PM »
I know you would have to excite the coil initially with 12v but i would think you could spin it with a drill? idk it would be hit or miss
« Reply #3 on: January 03, 2012, 06:47:28 PM »
spinning it with a cheap a/c motor would be easy. i know you have to give it a signal to make it work. it also needs a load or it will burn itself up. my neighbor rebuilds alternators and does all of mine, ill ask him whats involved
shogun
« Reply #4 on: January 03, 2012, 08:05:28 PM »
here they check them with a small 1hp electric motor, and they use a multimeter for meassuring it
« Reply #5 on: January 03, 2012, 10:35:40 PM »
thats useless without a load
« Reply #6 on: January 04, 2012, 11:28:38 AM »
Use a 12V motor to spin it. I know, brilliant! Now the trouble is to get it spinning... ;)
All you'd need for a load is a headlight or two & a car battery. I'm sure you can find some of those.
« Reply #7 on: January 04, 2012, 12:56:36 PM »
Colton already started this thread in the last 3 months.
