The tester reads:
170 psi
180 psi
190 psi
200 psi
210 psi
220 psi
230 psi
240 psi
250 psi
260 psi
270 psi
Author Topic: What's my compression?  (Read 13988 times)
« on: April 14, 2009, 11:08:53 PM »
"D16Y5 Type-R," 12.5:1 CR SOHC.  Basically a GX with an HX cam.  I pulled one spark plug and cranked with the other three in place @ WOT.  Guess.  :)
Re: What's my compression?
« Reply #1 on: April 14, 2009, 11:11:53 PM »
220
« Reply #2 on: April 14, 2009, 11:12:30 PM »
I know what it should be with a Y8 cam :)
« Reply #3 on: April 14, 2009, 11:14:23 PM »
I guessed 210psi
BangBusMaster
« Reply #4 on: April 14, 2009, 11:16:58 PM »
260
« Reply #5 on: April 14, 2009, 11:19:29 PM »
to fitty
« Reply #6 on: April 14, 2009, 11:21:33 PM »
over 270
« Reply #7 on: April 14, 2009, 11:27:35 PM »
over 9000
« Reply #8 on: April 14, 2009, 11:54:29 PM »
I calculated 265.23 PSI
« Reply #9 on: April 14, 2009, 11:57:35 PM »
0, its a trick question he blew a window in the piston
« Reply #10 on: April 15, 2009, 12:02:09 AM »
1 dollar!
I voted 240psi. :)
spoonfedcrx
« Reply #11 on: April 15, 2009, 12:19:45 AM »
0
« Reply #12 on: April 15, 2009, 02:20:26 AM »
260.  I had a nifty pic but my stolen internets went down again.
« Reply #13 on: April 15, 2009, 02:22:17 AM »
bout tree fitty
« Reply #14 on: April 15, 2009, 02:52:21 AM »
winner winner chicken dinner.
SOHCKLR657
« Reply #15 on: April 15, 2009, 04:17:48 AM »
750
stealthiskey
« Reply #16 on: April 15, 2009, 08:16:29 AM »
250, mulitply CR by 20
« Reply #17 on: April 15, 2009, 08:20:03 AM »
Gauge variance.
« Reply #18 on: April 15, 2009, 01:48:45 PM »
You mean this picture??
« Reply #19 on: April 15, 2009, 01:57:39 PM »
Hopefully this engine does not eat up your starter b/c of the higher comp.  ;D
Used to see it happen with high comp. build v-8's.
BoostForLife
« Reply #20 on: April 15, 2009, 02:18:16 PM »
D series starters are cheap and are all over the place.
« Reply #21 on: April 15, 2009, 02:18:31 PM »
230 is my guess
+1
*EDIT* 260 eh, wonder what its going to sound like when your starter is trying to start up and it explodes.
Spiker is to trannys
is what
JD is to Starters
« Last Edit: April 15, 2009, 02:20:53 PM by Urban Indian »
« Reply #22 on: April 15, 2009, 04:25:12 PM »
She turns over as easy as stock.  As far as I know it's the OG 320K mile starter, too.  I was caked in filth when I got the car and it's not been changed.
« Reply #23 on: April 15, 2009, 05:41:38 PM »
300 whp big compression all motor h22 spitted out 2 starters
Dr. D-Series
« Reply #24 on: April 15, 2009, 06:09:17 PM »
My old d15 w/ milled y8 head and zex 59300 made 235 across the board.
Yours sounds just right.
D16Y8-Z6.
« Reply #25 on: April 15, 2009, 08:27:30 PM »
That's some good numbers. I have 270 across my 11:1 stock bore/cam h23 vtak
« Reply #26 on: April 15, 2009, 09:01:12 PM »
Depends greatly on the cam, Wife's stang running 11:1 and timing locked out at 32 degrees cranks perfectly.
« Reply #27 on: April 16, 2009, 01:45:21 AM »
If you want, I'll make you a high-power WiFi antenna. By high power, I mean roughly 8x for a directional (180*) or 5x as power full (360*) vs the sorry POS that any pci or pcmcia card comes with. Maybe I'll do a write up... :somb:
« Reply #28 on: April 16, 2009, 05:55:37 AM »
A write up would be sweet. ;D :noel: :yes: :evil:
« Reply #29 on: April 16, 2009, 07:17:56 PM »
Antennas aren't poweredful, sir.
