Author Topic: Y7 valve spring ?  (Read 12413 times)
1slow91hf
Y7 valve spring ?
« on: April 15, 2009, 12:23:15 PM »
im working on the motor for my DD and was wanting to do a valve spring upgrade for high rpm
ive found a lil bit of info saying the Z6 and Y8 springs will work in the Y7 head but nothing beyond that and that thread was on HT  :?:
and for flaming issues
the DD motor is
Y7
P29 pistons
ARP rod bolts
delta regrind cam "dont know which im going to run"
"unknown springs/retainers"
OBD1 swap with P06 ecu running crome
stock injectors with ADJ FPR for now then throwing in a set of 310cc
Re: Y7 valve spring ?
« Reply #1 on: April 15, 2009, 12:37:37 PM »
i would use beefy a6 springs
mycarslow
« Reply #2 on: April 15, 2009, 01:51:46 PM »
im also looking into this for my y7
1slow91hf
« Reply #3 on: April 15, 2009, 02:39:58 PM »
i did find out that FJT has them listed as fitting the Z6-Y7-Y8
http://fjdistributors.com/product_info.php?cPath=47_49_59&products_id=175
 :noel:  :yes:
