Author Topic: explain centerline radius  (Read 18346 times)
7808
« on: April 15, 2009, 12:32:19 PM »
does a 1.5" pipe bend with a 2.25" CLR  means its a tighter bend then the same pipe with a 3" CLR?   or am i wrong, or CLR has nothing to do with how "tight" the bend is?
im trying to pick out some 1.5" mild steel bends on columbia river's site but the fuckin pics all look like the same bend.
« Last Edit: April 15, 2009, 03:48:44 PM by 7808 »
Re: explain centerline radius
« Reply #1 on: April 15, 2009, 05:46:53 PM »
http://www.bifab.us/lib/diagram.gif
read this link.
BTW: first page on my google search
slappynuts
« Reply #2 on: April 15, 2009, 08:14:03 PM »
clr is the yellow line down a road.
the white lines are the outside of the pipe
now, go bend the road into a 180
That should be someones sig.
« Reply #3 on: April 15, 2009, 11:51:55 PM »
done  :noel:
I was actually thinking about this shit earlier today.
mandrel-bends
« Reply #4 on: April 23, 2009, 02:14:04 AM »
Centerline radius is easiest remembered as half the distance between the center of the legs of a ubend.
Ie: 6" radius ubend, 12" center to center.
http://www.mandrelbends.com
