Author Topic: 90-91 bseries tranny question  (Read 14547 times)
« on: February 07, 2012, 05:12:42 PM »
ok have a 90-91 s1 tranny. now on all trannies I have done 94+ have a syncro on top of the main shaft for reveres. I pulled this one apart ans there is nothing there? I looked in the honda manual and it doesn't show this year tranny in it.  I'll try to get pics.
Re: 90-91 bseries tranny question
« Reply #1 on: February 07, 2012, 05:58:18 PM »
Look it up in the parts catalog using one of the online dealers.
www.acuraautomotiveparts.org is one.
« Reply #2 on: February 07, 2012, 11:59:38 PM »
92-01 have the 6th synchro, 90-91 USDM and JDM B16 do not.
Even more confusing is there are two different sizes for 3-4 synchros. Some are D sized, other are B sized.
« Reply #3 on: February 08, 2012, 12:14:03 AM »
The LS gear sets use the smaller sized synchros as the gears on the mainshaft as smaller diameter because of the lower numberical ratio.
1 and 2 are the same in the vast majority of B series transmissions.  Only 3 first gears options, and two second gear options that I am aware of.  At least for large spline transmissions this is the case.
Not really confusing unless you are privy to some other info that I am not aware of.
« Reply #4 on: February 08, 2012, 01:10:41 AM »
Thanks thats what I needed to know cause all I could find was info on the 92+ mainshaft but no 90-91. So does the bearing just ride on the hub?
« Reply #5 on: February 08, 2012, 03:34:37 AM »
Just like a D Series IIRC.
« Reply #6 on: February 08, 2012, 03:36:36 AM »
Only what I've been learning from HondaTech with Synchrotech and Gearspeed posting info. I only hit up the tranny forum EXCEPT for the Junk2 bullshit that went down last week.
