Author Topic: Quick and dirty aw11 tuning options  (Read 15251 times)
Rosecitycrx
« on: February 10, 2012, 04:14:41 AM »
Hey, do any of you nogs have experience with 1st gen mr2s? A co-worker of mine is trying to find a cheap way to tune it. All the message boards are full of standalone strokers. Can the stock board be modded to  run an emulator?
Re: Quick and dirty aw11 tuning options
« Reply #1 on: February 10, 2012, 09:45:38 AM »
No the stock board, can not be modified cheaply, TechTom (if I spelled it right) is the only way on those.
What is exactly being done to the engine?
Power adders?
Also if you ask nicely I'm sure there would a few members who explain the use of a good pgmfi (honda ems) conversion on his.  :noel:
« Reply #2 on: February 10, 2012, 10:04:38 AM »
A member on her did it to his mr2, from what I recall, work better, was cheaper and preformed better then the junk toyota put in from factory all while on e85.
« Reply #3 on: February 10, 2012, 10:11:41 AM »
Check these threads out.
http://www.realhomemadeturbo.com/forum/index.php/topic,15394.msg182917.html#msg182917
http://www.realhomemadeturbo.com/forum/index.php/topic,15227.msg179791.html#msg179791
http://www.realhomemadeturbo.com/forum/index.php/topic,4406.msg72162.html#msg72162
There is some nuggget of good info you have to just read and mine out what ya need.  :noel:
« Reply #4 on: February 11, 2012, 02:05:21 AM »
well for 200 bucks you can have a megasquirt
evo_lucian
« Reply #5 on: February 11, 2012, 05:19:27 PM »
X2 . Megasquirt 1 v2.2. There is a  write ups on diyautotune.com along with a basemap.
pitobread
  • I'm a llama.
« Reply #6 on: February 11, 2012, 11:58:58 PM »
MS1v2.2/v3, you can get them uber cheap.
Here are the pinouts for the AE86 jumper harness writeup I did,  AW11 should be the same/damn close.
MSPin = ECUpin as seen on the PCB = Color I used
37 = vc = Red
36 = igt = White
35 = #10 = Brown
34 = -
33 = #20 = Green
32 = -
31 = s/th = Red
30 = -
29 = -
28 = +b1 = Yellow
27 = -
26 = vcc = Red
25 = -
24 = ne = Blue
23 = ox = Blue
22 = vta = Yellow
21 = thw = Green
20 = tha = White
19 = -
18 = -
17 = -
16 = -
15 = -
14 = -
13 = -
12 = -
11 = e02 = Black
10 = e1 = Black
9 = e2 = Black
8 = e01 = Black
7 = -
6 = -
5 = -
4 = -
3 = -
2 = -
1 = -
If you want to read the whole thing... some other useful info in there too.
http://www.dorikaze.net/showthread.php?12892-Joel-s-Plug-and-Play-Megasquirt-how-to!
There was a guy in the UK that had done some neat stuff with the MAP based AW11 ECU, but I forget where I saw that at, and I am doubting you have a MAP based ECU.
« Last Edit: February 12, 2012, 12:05:45 AM by pitobread »
Rosecitycrx
« Reply #7 on: February 13, 2012, 01:33:07 AM »
Thank you guys for all the helpful tips. I figured megasquirt was gonna be the best option but I had to ask. I told him about the Honda set up but he didn't wanna go that path. we are trying to have a good out budget turbo shoot out. I have an a6 and he is trying to turbo his 4age.
Thanks pitobread, I'll save that pin out!!!
« Reply #8 on: February 14, 2012, 12:04:47 AM »
one thing about that write up is the ignition stuff, the canadian setup *might* be different. even if it is you can run a cheap bosch smart module, then all you do is trigger it off the led(same one in that pic).
kgx
  • MR2fag
« Reply #9 on: March 10, 2012, 12:26:18 AM »
There's a bloke in england who hacks MR2 ECUs. He's done both the 4AG and 3SGT. His name is Jeremy, and he used to post on MR2homoC as JMLRAW11 or something like that. Guy was a fucking genius. Hacked, wrote a GUI for and designed/produced a daughterboard for the 3SGT ECU in like 3 weeks. In his spare time.
This was about 5 years ago. No idea where he is now.
pitobread
  • I'm a llama.
« Reply #10 on: March 10, 2012, 01:49:56 AM »
Yeah I had an email correspondence with him a few years ago, North American ECU's use a different processor and are not the same as the ones he had been hacking.
