Author Topic: Small Block Chevy Single Turbo Build  (Read 65280 times)
JACER63
  • well shit..
Re: Small Block Chevy Single Turbo Build
« Reply #30 on: March 29, 2012, 02:16:44 PM »
looks like an awesome project.. i will be doing the same on my 63 nova, sbc 383 ,but twins.. here's a pic
hope you use some frame connecters on the car to tie the rest together, those unibody cars like to twist ..
« Reply #31 on: April 01, 2012, 06:36:41 PM »
This is giving me wood.  :noel:
Good work, keep the updates coming.  :noel: :noel: :noel: :noel:
« Reply #32 on: April 01, 2012, 07:45:28 PM »
DAMN!!!
JACER63
  • well shit..
« Reply #33 on: April 02, 2012, 01:10:44 PM »
no ladder bar .. it has a art morrison full frame and cage,full aluminum interior,basically the body is a shell.
soon i will be starting the project.. and your welding skills are looking good. keep up the work!
gfrg88
  • 2.0Si-T
    • Classic Prelude
« Reply #34 on: April 03, 2012, 07:26:02 PM »
This shit makes me feel like a dumbass for selling my Nova... Shit's gangster.
86 lude on steriods.
« Reply #35 on: April 12, 2012, 06:49:09 AM »
Looks awesome. How's the thermostat housing clearance though? I'm on my phone, but it looks pretty tight.
« Reply #36 on: April 12, 2012, 09:54:09 AM »
With all that good looking aluminum, the only thing I would change, is to put in some accufab, or vanjen or ect... clamps vs the silicone boots.
« Reply #37 on: April 12, 2012, 10:07:09 AM »
What size TB?  :noel:
« Reply #38 on: April 16, 2012, 10:11:34 AM »
3/8's O-ring would be my guess.
« Reply #39 on: April 16, 2012, 10:26:19 AM »
Call AEM.
« Reply #40 on: April 16, 2012, 10:44:23 AM »
That's what I figured but everything that I've seen that took a straight cut o-ring fitting, had a little race on the port to accept the o-ring. This doesn't.
Use -6 AN o-rings! The o-ring is put on the thread-less area at the base of the threads, and seal on the outter chamfer on the female fitting.
Either get a "straight-cut" fitting that only uses an o-ring, or cut off the flare end on the AN fitting. If it screws in w/o bottoming out, you can just pop on an o-ring.
« Reply #41 on: April 16, 2012, 12:22:24 PM »
Maybe npt?
« Reply #42 on: April 16, 2012, 04:39:08 PM »
3/8 oring would be a -906 I believe.
if a -6 AN is the same 9/16-18 thread an SAE -6 is.
« Reply #43 on: April 28, 2012, 03:54:55 PM »
Maybe npt?
Sounds like BSPP, which is the rest of the worlds version of npt, sort of.
« Reply #44 on: April 28, 2012, 06:50:18 PM »
i am familiar, hondas use that for the oil pressure switch. i tap all of my blocks for npt, to make turbo plumbing easier
« Reply #45 on: April 30, 2012, 12:17:10 AM »
gangsta!!!
« Reply #46 on: April 30, 2012, 12:51:06 AM »
oh my fuck.
« Reply #47 on: April 30, 2012, 04:55:25 PM »
bad ass
« Reply #48 on: May 20, 2012, 01:14:31 PM »
Can't remove radiator, etc and swap the cam out?
« Reply #49 on: May 25, 2012, 01:08:25 PM »
carkrazed didnt you have a xr4ti at one point?
