Author Topic: 90-93 integra fuel line?  (Read 17677 times)
« on: March 02, 2012, 11:36:47 PM »
anyone know the size or fuel line and return? just from the looks of it they appear to be the same size. Going to upgrade to 3/8" fuel line and not sure if the stock return it big enough.
By the way got a da as new project.
Re: 90-93 integra fuel line?
« Reply #1 on: March 03, 2012, 01:45:23 AM »
The only time a 255HP pump is too much for the stock system is when you're using the stock FPR.
Worst case you have to retune some higher vac columns because the fuel backs up and raises fuel pressure. Just keep it in boost and you won't return any fuel. ;)
« Reply #2 on: March 03, 2012, 03:48:52 AM »
Only time I've ever heard of that is when the small stock fpr is used.
« Reply #3 on: March 03, 2012, 11:01:18 AM »
Interestingly I found this at d-series.org (by someone we know):
Quote from: Joey Misanthropy
You need a B-series FPR for a 255HP, the outlet is visibly larger so it's a no brainer if you have to pick one up out of a parts jumble. Without the B-series unit your fuel pressure at idle will drift, but it is fine during the operating range as pressure is bled off by the injectors.
I've taken a stock B-series FPR and fuel lines to 700 whp. In the 350 whp range the pressure from one side of the rail to the other varies ~4% which can be dealt with via individual cylinder trims, but don't trust it too high.
« Reply #4 on: March 03, 2012, 01:30:09 PM »
Happened to me with large and small outlet stock FPR, even with modified one (drill a hole between passages).
I was using CDM 255lph HP pump and would max out past 200psi.  :noel:
« Reply #5 on: March 03, 2012, 03:27:15 PM »
never had this problem because I have always had a large fpr. Even on my d series I had a large b series fpr.
« Reply #6 on: March 03, 2012, 09:45:13 PM »
i have never noticed it with a small fpr. i do have a big one now, but my idle with the small one was always solid
« Reply #7 on: March 04, 2012, 12:41:48 AM »
I run a f fpr the out let on it is larger than my ls fpr is.
« Reply #8 on: March 04, 2012, 08:20:05 AM »
Not all LS have the big one. Just some
« Reply #9 on: March 04, 2012, 04:02:02 PM »
I see. I had to use the f one cause the out let is angled and cleared the ge manifold.
« Reply #10 on: March 19, 2012, 12:03:56 AM »
Yup, most accords in the yard have the large exit oem reg.
Keep an eye on your crush washers for the pulsation damper.  I've seen the wrong ones used n cause high pressure before the rail, but not enough in the rail...
Does anyone know the size of internal threads of the fuel rail?  I think they're m14x1.5, but have been too lazy to measure...
« Reply #11 on: March 19, 2012, 09:02:31 AM »
No clue, but I have a z6 rail with the stud out. I'll try to remember to check it when I get home tonight.
« Reply #12 on: March 20, 2012, 07:40:17 PM »
Just got off my ass, it's M12x1.25...
